Question about Casio Office Equipment & Supplies
Old Casio CP-10 printing calculator w/calendar
How to set date & time? There's a "all reset" button that sets to "1901-01-1" and 12:00:00 . . . .and a "set" button that doesn't seem to do anything. I'm guessing it's some combination of keys, or key sequence to set the date and time . . . . anyone have a guess?
  • Casio Master
  • 13,433 Answers
Lets see if I can get my hands on a user manual.
Posted on Jun 25, 2008
    Brigadier General:
  • 3,614 Answers
Have you try to press the SET button after you enter the date, and before you make entry on the time
    Master:
  • 848 Answers
Just press the set button followed by the numbers for setting time
  • gopinath pasupathy Jun 25, 2008
    try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
Apr 09, 2010 | Canon MP-11DX Calculator
Setting date and time, I put in correct date but doesn't stick ,
Apr 08, 2010 | Canon MP-11DX Calculator
How to reset the clock?
Push the button with the clock and calendar, this is directly over the 'cost' button, to display the date or time. Then use the 'Time set' button (this is the one for Memory - Plus - Equal). Hold the 'Time set' button down until the first figure blinks then release it. Use the number buttons to change the setting. When you have gotten the correct date or time entered oress the 'Time Set' button again.
Although it is only printed with 'Time Set' the button works for the date just as well.
Mar 30, 2010 | Canon P23-DH Calculator
Changing the date.
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 15, 2010 | Casio DR-T120 Calculator
I need help to set the date and time
turn adding machine on. press reset button on back with pointy object. press the button picturing a calendar/clock. this will bring up the date. press & hold the "time set" button (same as M+/-) enter date on number pad. press time set to save. repeat for time
Mar 26, 2009 | Canon P23-DHV Calculator
I have the same problem I can not change date and time
Setting the date:
Setting the time:
displayed.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
Aug 09, 2008 | Canon MP-25DV Calculator
Calender
First Remove the clear tape from the battery compartment on the bottom. Second take a paper clip and press and hold the reset button for 5 seconds. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the date and press time set (M+/=) until it stops flashing. Then press the calendar/clock button. Next press and hold the time set button (M+/=) until the first number starts flashing. Type in the time and press time set (M+/=) until it stops flashing.
Apr 28, 2008 | Canon P23-DH Calculator
Reset time and date
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Mar 12, 2008 | Sharp EL-2196BL Calculator
Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Feb 20, 2008 | Sharp EL-2630P Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
422 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
