Question about Canon imageCLASS D780 All-In-One Laser Printer
Document feeder on top of machine
Top document feeder doesn't work.
I found a solution on your website giving a list of replacement parts to solve the problem. Unfortunately, I did not write down the site or the list of parts. In the end, I located a printer repair website that uses local technicians to repair the copier. I am waiting for a reply from them giving me a list of references in my area. So, the copier is not fixed - yet. I may be contacting you for your help so I've saved your email to me.
Thanks. You did help me in the past to fix my car cd changer. The dealership wanted to replace the unit for $600.
Posted on Jun 26, 2008
How to set document feeder on top to work?
Sir/Mam,
Recommend that you have the technician come back out and reseat all the connectors he removed when in stalling the new circuit board. One connector mite not be seated properly or a connector pin was bent!!!
Feb 07, 2014 | Konica Minolta Bizhub C253 With Document...
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Line thru the documents when using top feeder
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
hth,
razors
Nov 28, 2011 | Brother Office Equipment & Supplies
Cannon MF6580 fax machine says check document. i have tried everything, any suggestions?
Open the top cover of the document feeder and look inside where the paper goes into machine. There is a flag that comes loose and the machine thinks there is paper in the feeder. You have to remove the top cover carefully(just a tab on each side of the cover). After removing the cover there should be another cover on that cover remove a couple of screws and take it off. Put the flag back into its holder and put everything back together....Carefully!!!
Nov 30, 2009 | Canon Office Equipment & Supplies
Document does not feed
Pull up to open the document feeder. Clean rollers and pad with alcohol.
Jun 09, 2009 | Brother IntelliFAX 2800 Laser Fax
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
I have a WorkCenter M20 and I am unable to use the document loader on the top of the machine... why is this? I try to load the documents and press start, but then onlty a blank sheet is spit out, because...
What you want to do is this. Turn the machine off, then go to the back of the machine and unplug the document feeder, There is a white connector with 2 thumb screws holding it in place. loosen the 2 thumb screws and unplug the plug. With the feeder unplugged turn the machine back on and let it come to ready. Once it comes to ready turn the machine back off, then plug the document feeder back on and turn the machine back on. That should re detect the document feeder and work fine. The M20 for some reason just forgets it has a feeder and you have to force the plug and play portion of the software to detect the machine not having a feeder then seeing that is has one. I don't know why, not even the newest versions of firmware for the machine resolves that issue. Odd,,,,,
Mar 13, 2009 | Xerox WorkCentre M20 Black and White...
Canon imageCLASS D780 All-In-One Laser Printer Logo
82 people viewed this question
old marine
old marine
