If you are just using it as an external drive, Fedora should see the drive automatically, no driver should be necessary. If it can not, there is probably a different issue.
You may need to format the drive if order to mount it.
If it is already formatted as NTFS, it will be read-only to Linux. If formatted at FAT32, Linux should be able to read-write it as well as Windows.
fdisk -l: to get info on all disks (formatted or not) connected to the box. You should be able to figure out which disk is which.
If you will be using this disk exclusively with Linux, you will probably want to consider formatting it with a native Linux file-system.
