Question about Hotpoint Refrigerators
Defrost Fan Hi I have a Hotpoint FF187MP with a warm fridge. I have been advised to defrost the fan by using a hair dryer all over the back for 10 minutes. I have done this but other than waiting a couple of hours to check temp, how can I check to see if it has worked? fan in freezer does seem to blowout but I can't feel it in the fridge (not sure I ever noticed if it did). Cheers.
    President:
  • 1,462 Answers
If back is badly iced up it will take longer than 10 mins to defrost - iv'e known it to take an hour.
the amount of air going up to the fridge is not great but you should be able to feel it thro the grid - wet you fingers and you will feel it better
Posted on Jun 25, 2008
My whirlpool gold freezer is working but my fridge is warm I have an upper fridge and freezer is on bottom how can I fix it
all the machine does is the evaporator coil in the freezer gets cold,there's a fan in the freezer that blows the cold air from the freezer up into the fridge section and that's it,so if your fridge is warm you either have a bad evap fan motor or you could have a defrost problem,check to see if there's any ice or like snow on the back inside wall of the freezer,if so you have a defrost problem and you'll have to see what part is bad,if it is a defrost problem,you can shut the machine down or unplug it,take the food out of the freezer and if you can remove the back inside wall so you can melt out all the ice on the coil and air ducts,this will give you like 10 to 12 days to fix it or call someone in to fix it before the coil freezes up again,you can use a hair dryer to do this,or there could be a damper inside the top of the center back wall,you'll see slots in the top of the tower on the back wall,if there's a damper the damper door might be closed not letting any air in,next time send the full model number off of the fridge so whoever answers you can see what you have,if the freezer is on the bottom usually if you open the fridge door or the right french door,look up on the right wall near the ceiling and you should see a tag,if not there look on the other wall or ceiling they used to be on the right wall but on some of the newer models they moved the tag, nice guys lol.so open the freezer door,listen for the fan,if you don't hear the fan that could be your problem,check the back wall for frost,you could have a defrost issue or if there's ice on the back wall and the ceiling the door could have been left open,common problem with bottom mounts,if so if you google the model number you can find how to manually put the fridge into defrost,this turns the heater on in the freezer to melt the ice off of the coil,you can then get in there with a hair dryer and help melt it out,when you don't see any water dripping down and you can see it through the slots that are cut in the back wall of freezer your all set.the problem is the air ducts are frozen up and the air can't blow from the freezer and into the fridge.hope this helps you out but without a model number this is the best i can tell you.
Nov 23, 2017 | Whirlpool Refrigerators
Hotpoint fridge freezer mod no fufl 1810 not working properly .food in fridge warm and freezer food starting to defrost. Have to turn on and off at plug before it kicks in again.... Any ideas
I have the samo model with same problem!
Try to do defrosting 24 hours! You can remove the back cover of freezer (inside) and check is there ice on the evaporator (looks like a radiator) If ice is there you can defrost by hair dryer!
Check after, should be ok, but I have a bad news! You have defrost system problem like me.
Mar 15, 2015 | Hotpoint Refrigerators
Hotpoint FFB6187
sounds like 2 things either the t stat making fridge run all the time, or 2 the fan not having enough cfm to circulate the air.
Nov 06, 2013 | Freezers
Side by side fridge freezer
That sounds like one of your cooling tubes is frosted up IF your fan is working. Pull the read freezer shield off and check for an ice buildup around the evaporator coil. If so, defrost circuit problems. If not, use a hair dryer and blow air down the cooling tubes to defrost the tubes.
Jan 23, 2012 | Refrigerators
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer wont defrost and refrigerator is to hot
the evaporator coils in the freezer are iced up. either someone left the door ajar for a while, you didn't let the fridge sit empty and turned on for a day before filling it, there is an obstruction in the evaporator drain causing water to pool and freeze on the coils, or your evaporator fans are not working. you need to unplug the unit and either: 1- let it set with the doors open and defrost with the ambient air (and soak up the excess water under the fridge); 2- find the back wall where the frost is, take the screws out and remove the wall, and use warm water to melt the ice on the coils (and soak up the excess water); or 3- use hot air (hair dryer). be careful with the hair dryer. just enough to melt the ice and not to heat up the fins and tubing. clean up any extra water inside, check the drain under the coils for obstructions, make sure the fan works, empty the fridge, turn it on, close it, and fill it tomorrow. also, there is a self-defrost timer on the fridge. look in the manual for it's location and setting.
Jul 20, 2009 | KitchenAid KSRG25FK Side by Side...
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
My Bosch upright fridge is not defrosting & has a wall of ice on the back. The fan does not appear to be working either. Is that the problem? - cant remember how often I see the fan working now!Thanks
I kind of doubt that the fan is the problem. On my refrigerator, when it goes on defrost, the fan shuts off. They don't want it blowing heated air on the milk. Yours might be different.
I don't know this particular frig, but evidently the defroster doesn't work. Perhaps the fan doesn't work also, or perhaps the fan would work if the defroster were fixed.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
I think that when the defrost heater is turned on, then the fan is likewise turned off. The defrost thermostat, I think, is doing it's job, letting it cool again. But the timer is stuck. Or something???.
Hope you can fix it.
Aug 18, 2008 | Bosch Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
