Question about Minolta bizhub 200 All-In-One Printer
Bizhub 200 printer
Our printer is showing a malfunction error code of C0204....any suggestions?
    Problem Solver:
  • 6 Answers
Tray two elevator motor failure. Make sure you dont have anything sitting under the trays and also make sure the trays are level
Posted on Aug 24, 2008
Konica minolta bizhub 163 error 0045, what I do to work
from what I've read here:
Error Codes Konica Minolta bizhub 163
, this is a Fusing Cooling Fan Motor malfunction, which suggests, I'm afraid, that you have to have it serviced.
Kind regards,
Jon Erik
Nov 14, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub 250 error code c0204
Paper behind the draw or the paper not properly placed in the draw. DO NOT STORE EXTRA PAPER in the draw because there is extra space the extra space is for 11x17
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0204
PULL out the second tray remove any and all paper from behind the draw also REMOVE all the STORED paper on the left hand side of the draw that is not a storage area. Storage draw is used. The space is for if you decide to 11x17 paper
Jan 23, 2014 | Minolta bizhub 200 All-In-One Printer
C0204 error
Remove the second draw and remove the paper from behind it. Then remove the extra paper in the second draw that is sitting on the left hand side that is not A STORAGE location . It is for 11x17 paper.
Nov 12, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 error 107
Could not find that code on the Bizhub 200 service manual< normally a C will be the start of the code.
Feb 11, 2013 | Minolta bizhub 200 All-In-One Printer
Need help w/ bizhub c350< error code is c-0204
error code c0204 means the yellow drum unit corona has failed the drum unit needs to be replaced this unit may also be called an image unit
Sep 27, 2011 | Office Equipment & Supplies
Tray 2 elevator failure. Something is wrong with the paper lifting in tray 2. Most common cause is improperly loaded paper in the tray so I would check that first. If you can't find any issues with tray 2 then you can leave it open an inch or two and reset the code so you can still use the copier. Then have a tech look at the tray as you could have a lift motor or lift sensor going bad.
Good Luck and Thank You for using Fixya.
Nov 18, 2010 | Minolta bizhub 200 All-In-One Printer
Bizhub 200 Copier: Copier says malfunction...
if copier is saying malfunction, then look it will also showing the code, note the code then inform me...........
May 16, 2010 | Minolta bizhub 200 Copier
How do I remove drawers 1 and 2 from Bizhub C200 - am getting error code C0204
Pull out the trays, locate the metal tab on the copier frame that is held in with one screw. Remove the screw and angle the tray out.
Feb 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
Minolta bizhub 200 All-In-One Printer Logo
776 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
