Infocus mod.610/620 Lite pro
Unit shuts down after 15 to 30 minutes.Fan continues to run,
Changed lamp but still have problem.T o restart,I must turn
off main switch then back on.Please help.
Bob
bobbytrue@msn.com
  • 1 more comment
  • bobbytrue Jul 17, 2008
    There appears to be three fans in this unit.One is to cool the lamp,one is in the bottom and must be to cool the power supply and electronics.The other one is small and I don't know wha its purpose is.It seems that the fan in the bottom became unplugged fron the circuit board and was not running.
    I guess there is a high temp.shut down switch that was shutting the unit down.I ran the unit for about 45 minutes and it was still running.I will test it further in a day or so.Thanks for all the
    suggestions.Bob
  • dc20_02 Mar 02, 2009
    i have a infocus In24 it works fine for about 30 minutes to 45 then it suddenly turns off..the lamp life is still good..if i unplug the unit i wait for about 5 to 7 minutes to turn it on and it works for about another 20 minutes or so..and then it suddenly turns off can any one help
  • dugenkov May 11, 2010
    For me a projector ifocus lp70 +. Tried to substitute for it firmware
    the computer has written that does not understand the data which come
    from a projector. I have interrupted operation and now a projector for
    me does not switch on. At inclusion in a network for it the red bulb
    shines the fan and in the rest too silence does not work. How to it to
    make hardreset? Or what that in this spirit?
    Problem Solver:
  • 17 Answers
Sounds like either a power supply issue, which will cost more than the unit is probably worth. or the thermo- sensor may be flaking out, which may not be too costly to repair.
then there may be bigger issues but i would guess 1 of the 2 mentioned
Posted on Jul 17, 2008
My infocus t160 turns on and after a minute it shuts down and the lamp and temp (signal) is on
The fault may be the cooling fan, it may have dtopped working and caused the unit to shut down.
Aug 25, 2011 | Computers & Internet
I have an Infocus IN2102EP projector. It was shutting down after several minutes of use. I contacted InFocus support and they advised to change the bulb. I've changed the bulb and reset the bulb hours. ...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 04, 2011 | InFocus In2102 Projector
My infocus 1503 works however once it is turned on the unit sounds as though it is ready to take off. The fan is very loud then after a few minutes it quiets down and then the fan becomes very loud again....
I own two of these projectors. You need to update the firmware to 1.03 which can be found on the infocus website. This solves the fan issues which also causes premature shutdown of the projector. Once you download the update, open it, there will be step by step instructions on how to do this procedure. I could not get this to work with Vista 64 so you might need to run this on XP or 7.
Mar 11, 2011 | InFocus IN1503 DLP Projector
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Infocus LP 280 runs for 1 min then shuts down, runs again then
are the leds on the top lit or blinking? it could be the lamp, the ballast, or the fans. check the lamp. if there are black spots or bulges in the lamp, replace it. if not, make sure the fans are running. if they are, replace the ballast.
Jun 09, 2009 | InFocus LP 130 Multimedia Projector
Mod.620 shuts dowd.
Everytime that you use to change Lamp, the unit system timer must reset or setup again... You can see and change this option in the MENU SETTING using the remote control of the unit..
Regards,
micro
Jul 13, 2008 | InFocus LP 600 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
LP 540
1. Have you recently changed a lamp and if so, Did you reset the lamp timer and is your filter (if it has one) clean?
2. can you hear a FAN start when you turn the unit on?
Jan 15, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Infocus 4805 problem
Make sure that the lamp plug is properly plugged. 3 flashes indicate this or a faulty lamp.
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
817 people viewed this question
jasbo
jasbo
