Question about KitchenAid KUWS246E Stainless Steel Wine Cooler
Wine cooler 2nd time it happened!! The on and off dial button (thermostat) does not work. The light switch works but the the cooler does not turn on. The last time the tech replaced the thermostat. Could the same hold true 3 yrs later???
  • home23 Aug 29, 2008
    Exactly the same problem and for us the second fix, too! First time was about 18 months after installation and now today. Unit was installed in May 2003.
  • jordanp54 Sep 28, 2008
    Me too. 9/29/08. I'll get a thermostat and see if it is the answer for me. I'll let you know.
Thermostat again.
Posted on Jun 26, 2008
It just stopt cooling (
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
My marvel wine cooler is 9 years old and no longer runs. The light works but nothing else runs. Might this be the thermostat? iif so where would I ge a replacement and would would it cost?
This could very well be the thermostat (pre-2000) or part of the temperature control system (2000 to 2009) which has three parts: The thermsitor (usually the culprit), the potentiometer (connected the the control dial) or the control board. Call the factory at 800-223-3900 with your serial number (to identify which control it uses) and you can buy the part direct from them. The control kit is about $150.00, the old style thermostat about $100,00 and if it is just the thermsistor, it's about $50.00 (I haven't checked their prices in awhile)
Jan 18, 2010 | Marvel 61WC Wine Cooler
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Thermosthat doesn't work
Hi , yes it sounds like the thermostat is stuffed.  To replace it is relatively simple but always keep in mind , switch off and un-plug it before working on it for safety ,  to replace it you will need a phillips head screw driver , a flat screw driver and a note pad,  where the dial is , that is the thermostat , the surrounding screws are what hold it in position so removal is only a matter of having a real good look inside . Thermostats for this purpose are about $15 to $35 dollars depending on your country . replacement time is about a hour depending on how much trouble to have getting the old one out. remember that this device has a small alloy tube which is the sensing part of the thermostat , be careful not to damage this because it carries a small refrigerant charge which is the primary temperature sensor so please be very careful and above all take your time .
I hope this helps you ,
Thank you and have a nice day:)
May 12, 2009 | GE ZDW24A Wine Cooler
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
KitchenAid KUWS246E Stainless Steel Wine Cooler Logo
409 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
