Question about Intel D102GGC2 Motherboard
RAM NOT DETECTING
HELLO FRIENDS,I HAVE BEEN USING INTEL D102GGC2 MOTHERBOARD FOR 1 YEAR.I HAD 512 MB DDR2 RAM,AND NOW I HAVE BOUGHT ANOTHER 1GB DDR2 MEMORY SLOT FOR UPGRADING MY RAM MEMORY.THE PROBLEM IS THAT WHEN I INSTALL BOTH MEMORY SLOTS ON THE BORD,THE BORD IS DETECTING ONLY 1 GB MEMORY SLOT.ANOTHER 512 MB CARD IS NOT BEING DETECTED BY BORD.
BOTH MEMORY CARDS ARE OK.AND BOTH MEMORY SLOTS INSTALLED ON THE BORD ARE ALSO OK.I AM ABLE TO USE ONLY ONE MEMORY AT A TIME.
I HAVE CHECKED BIOS,AND IT IS ALSO NOT DETECTING 512 MB DDR2 MEMORY CARD.IT IS SHOWING THAT THE SLOT IS EMPTY OR THERE IS NO CARD INSERTED IN THE SLOT.MY MEMORY CARD ARE 667 MH. -ROHITASHVA DONGRE
  • 1 more comment
  • Anonymous Jan 01, 2009
    same here
  • jeet_14382 Feb 05, 2009
    Yes i have same problem with D102GGC2 Mother board i also bought 1GB RAM and its working. but i insert 512 MB RAM in to slot its not detected. any setting for using both on motherboard
  • Rohan Dullur
    Rohan Dullur Nov 04, 2013
    me too same problem!
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Posted on Jan 16, 2010
HELLO FRIENDS,I HAVE BEEN USING INTEL D102GGC2 MOTHERBOARD FOR 1 YEAR.I HAD 1GB DDR2 RAM,AND NOW I HAVE BOUGHT ANOTHER 1GB DDR2 MEMORY SLOT FOR UPGRADING MY RAM MEMORY.THE PROBLEM IS THAT WHEN I INSTALL BOTH MEMORY SLOTS ON THE BORD,THE BORD IS DETECTING ONLY 1 GB MEMORY SLOT.ANOTHER 1 GB CARD IS NOT BEING DETECTED BY BORD.
I HAVE CHECKED BIOS,AND IT IS ALSO NOT DETECTING 1GB DDR2 MEMORY CARD.IT IS SHOWING THAT THE SLOT IS EMPTY OR THERE IS NO CARD INSERTED IN THE SLOT.MY MEMORY CARD ARE 667 MHZ. - SHYNESH
Posted on Jan 04, 2009
I have this motherbord and i have bought 1 gb ddr 2 (Sumsung) 800Mhz
and this work good with my old 512 mb ddr2 = 1.5 Gb
Posted on Jul 11, 2008
    Problem Solver:
  • 15 Answers
Nice ram cool my pc works well but u shud go see pc wrld they might be able to help mate
andrew
Posted on Jun 25, 2008
  • jebend Jun 26, 2008
    hi ur a nob
    soz my bro typed that
Just clean the memory slot which was not used earlier. There might be dust in the slot. And try u r Luck :)
Posted on Jan 08, 2009
667MHz not supported by 102
only 553/400 MHz and only 2 gb maximum
ok
Posted on Jul 05, 2008
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Heating problem
i am having 1GB Ram in Single slot,when I add another 1GB ram in the other slot the memory shows only 896Mb.The processer is dual core.
Dec 05, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
704 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
