Step
Disconnect the negative battery cable from the terminal on the battery. Remove the upper and lower
steering column covers by unscrewing or unclipping them.
Step
Remove the steering wheel by lifting off the center cover,
disconnecting the horn wire and removing the retaining nut and washer.
Make a mark on the steering wheel spline and the wheel itself so you
can line it
back up precisely. Pull the steering wheel straight back to remove from the shaft.
Step
Take off windshield wiper and turn signal switches by pulling them off as you did the
steering wheel and disconnect the wiring. Slide the spacer sleeve off of the steering column.
Step
Unscrew the ignition switch mounting screws. Pull out the ignition
switch. Disconnect the wiring connector from back of the ignition
switch. Simply loosen the tabs and pull it out.
Step
5
Insert your key into the ignition. Turn the ignition switch to the
locked position. Depress the retaining pin with a small screwdriver and
turn the key to the Off position to free the cylinder. Once it is free,
turn the key to lock position and remove the key and key cylinder.
Step
6
Install your old key cylinder into the new ignition switch assembly.
Make sure the contacts in the cylinder and assembly line up. Reattach
wiring to ignition switch, slide it into place, screw in mounting
screws and reassemble steering wheel and switches.
