Question about RCA Televison & Video
Tv will not turn on. stand by lite does not turn on
    Sergeant:
  • 260 Answers
  • maker sure television cord was not accidentally unplugged
  • check breaker box in home to make sure all electricity is working properly
  • make sure other units plugged in to the outlet are working properly
  • unplug tv for 2 minutes and plug it back in
  • call repairman using FixYA repair service to find a local repair service near you.
Posted on Jun 25, 2008
Why no picture, no sound?
that is stand-by problem,if u r a technician,than you check the stand-by circuit thoroughly unless you have call the customer care
Jun 08, 2015 | Sony Kdl-52vl150 52" HDTV LCD TV
The stand by power lite is steady until you try to turn the tv on, When the tv is powered up, the standby light blinks 6 times, the tv then turn off. no picture or normal sound. what do the six blink codes...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Mar 11, 2015 | Hisense 32K20DW 32" 720p 60Hz LED Smart...
2006 sony wega vertical lines green lite blinkspower stand by has sound
This is normally caused by the DIC block being defective and will need to be replaced. However the optical block aka light engine has been known to cause this also, But is very rare.
Mar 18, 2013 | Sony Grand WEGA KF50WE610 50" Rear...
Stand by lite blinks 4 times its turns itself after 4 min
This may be a problem with one or two MCZ chips....not sure if this model has them or not. Check the site www.TvRepairKits.com just in case.
Apr 22, 2011 | Sony KP-61HS30 TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony trinitron,standby lite flashes
Hello mybuddydakot,
This is an indication that the shutdown circuit is functioning which means there is a high current event happening in your set. I would venture to say that the problem may be in your high voltage section. I would suggest that you take the set to a qualified TV repair shop, due to the nature of this possible problem.
The High Voltage section is dangerous and should be worked on by a person who has knowledge of television electronic technology.
I hope this helps,
Shuttle83
Nov 18, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
ESA 42" plasma will not turn on
Find a power supply that was the problem with my. Exept my tv now dont have picture Cause ysus board is dead..
Nov 10, 2007 | Televison & Video
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
