Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Master cool blower motor?
It seems to be working but it i can hear it clicking alot?
    Novelist:
    Champion:
  • 230 Answers
If this is a regular roof mounted unit then I will suggest that the motors internal clutch could be failing. If your unit is ducted then it could be something in the duct like paper. Sometimes as the wind flows through flex ducting it can also make this sort of noise.
If this is a portable Evap cooler then there is a rod that extends from the main blower to the pump assembly. You can probably see it turning with a flash light. If it is wobbling then it could be the pump or gear. As usual make sure the unit is clean and all the water ways (including the hoses) are clear of obstructions.
Posted on Jun 25, 2008
2000 f350 air conditioner/heater control. When I turn the switch I can hear vacuum sounds but no air will blow out, resolve problem
Do you hear the blower motor running ? Can you switch from low to high speed an hear the blower motor switch from low to high ?
Feb 09, 2017 | Ford F-350 Cars & Trucks
The rigt side does not seem to be working but the left side is. We put a new bulb in but it is not the bulb. Could it be the motor
There is 3 motors, a compressor motor, an outside blower motor and an inside blower motor. Most likely it's your inside blower motor not pushing air across the cooling section of the fridge. Air flow problem may be a seized blower motor, or frost build up.If all 3 motors work and there is good airflow, then some refrigerant may have leaked out.
Jan 31, 2015 | Refrigerators
Wirred into system gas valve will not open
Possibility solenoid valve is not working u shud hear a click when it opens
Oct 05, 2013 | Honeywell ST9120U1011 Fan Timer Universal,...
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
The a/c in my acura legend 1995 stopped working while it was running. The button still works because when I turn on the a/c button, I hear a click right under the blower fan but the blower will not c
Check the power going to the motor to see if it's good. If it's ok, you can try tapping on the motor with handle of a screw driver or something similar, it might kick on. If there is no power, check the fuse. Otherwise there might be a switch or module problem.
Dec 12, 2012 | Acura Cars & Trucks
My 1995 Sierra blower quit.
probably the blower motor.
Jul 18, 2010 | 1995 GMC Sierra C1500
Blower fan not working - Hyundai 2004 Santa Fe
Try a SHOCK test to the blower motor case. What I mean is SHOCK the case by hitting it with the palm of your hand (make sure you have the blower switch 'HIGH' and the IGN key also 'ON'.. if the blower starts working, you have an intermittent contact in the motor itself. If this doesn't work, get a test light and connect it to the connector that plugs into to the blower motor - if the test light illuminates, then the problem is obviously in the motor. If it doesn't, then you have a wiring/switch/power supply problem.
May 21, 2009 | 2004 Hyundai Santa Fe
Rear cooling and heating blower motor does not work
its not in the headliner. its under the side panel in the rear on drivers side. you half to remove the panel on the inside just above the rear tire. since the moter runs sometime i would replace the blower motor resistor first cause these are known for going bad and its in the same area as the blower motor. this resistor controls the fan speeds and if its gone bad the fan dont run right. plus its alot cheaper than blower motor. once you have replaced the resistor you can turn the fan on and see if its a fixya before putting the panel back in place.
Apr 24, 2009 | 2001 Ford Windstar
Blower for heater stopped
Remove the hush panel under the dash and unplug your blower motor turn the knob and see if its getting power. If it is replace the blower motor. If your heater seems to work on high but not the other 4 settings. replace the blower motor resistor and pigtail (same general location as blower motor)
Jan 31, 2009 | 2004 Chevrolet Silverado 2500HD
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
371 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
