Question about Olympus D-630 Zoom Digital Camera
Camera shuts off immediately when I try to turn it on
When I press the power button, the screen appears for a second, then turns off and the lens never opens. I can press the play button to review my saved pictures on the memory card, and the battery is fully charged, so that isn't the problem. I see that several other people are having the same issue with their cameras. please help! My cmera has the same problem I dropped it and now I switch on screen appears for a split second but lens refuses to come out.
    Brigadier General:
  • 3,614 Answers
It is better to put the camera on service center and get a professional do the work.. it is not advisable that you will re assemble and try to fix that thing if you don't have any professional background troubleshooting the unit.
Posted on Jun 25, 2008
  • 1,879 Answers
Greetings,
Since the camera was accidentally dropped (very sensitive mechanisms inside), mechanical failure inside the camera.
It needs to be serviced or check your warranty status from the manufacturer or place of purchase.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Novelist:
  • 121 Answers
Try removing the battery for a couple of minutes and then plug it back in. When it was dropped was the lense sticking out? If so it may have jammed. You can try resetting it by taking the battery out for a couple of minutes and then putting it back in. If that does not work take a look at it when you turn it on and check and see if the motor is hanging up when the lense trys to adjust. If this is the case you will need to have the camera serviced. Good luck and if you found this solution helpful please rate it when you get a chance. Thanks - Tech101
    Sergeant:
  • 260 Answers
Typically this means that the sensor that let's the camera know you are ready to take a picture has been damaged. You will need a technician to look at this to see if it can be repaired.
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Camera starts, but shuts off immediately afterwards
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 01, 2009 | Canon PowerShot A95 Digital Camera
When the camera is turned on with the power button the lens comes out and stays out but the camera immediately shuts off and the lens stays open. The only time the camera remains on is when the dial at the...
Please try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 13, 2009 | Sony Cameras
Power on, boots, then shuts down
I believe you have a defective Exilim memory card. Try replacing the memory card and see what happens.
Mar 27, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Olympus D-630 Zoom Digital Camera Logo
62 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
