Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cant transfer files
My desktop & laptop computers recognise the USB drive but I can't transfer files to it. I have tried both the drag & drop and the copy and paste but keep getting a message saying can't copy, drive full or corrputed. This is a new USB which contains U3 software.
Can anyone advise please.
  • 3 Answers
Tell us that which operating system that you are using and which USB drive you have...is that from sandisk or what...?
Posted on Jun 25, 2008
How do I transfer movies, from a usb stick onto my Apple Mac laptop, then back to another usb stick
1. Plug in first usb stick
2. Open finder and locate the usb stick and the movies within
3. Drag and drop the movies on to the desktop
4. Plug in the second usb stick
5. Open it in finder
6. Drag and drop the files from your desktop to the usb stick
Feb 06, 2016 | Apple Computers & Internet
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Download from sandisk flashdrive to computer files
Just plug it in a USB port. Use Explorer to explore the drive. Locate the files you want to transfer to the computer. .Drag and drop it on the desktop or anywhere else. You can also use CTRL Copy, followed by CTRL V to paste at the location you select.
Oct 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I work on my data on the Seagate FreeAgent 2TB GoFlex Desktop USB 2.0 Hard Drive as my computer memory is at capacity. I want to be able to use my external hard drive as an extension of my computer...
Assuming you are using a Windows operating system, you can just plug it into your computer's USB ports, and the computer will recognise it as another hard drive.
Instructions:
Double-click on 'My Computer' and take note of what drive letters are there (C:, D:, etc.) before you plug in the Seagate Freeagent.
Plug in the Seagate Freeagent. You'll see the new drive, likely E: or F: (depending on what is already there before you plugged in the Seagate Freeagent)
Double-click on the new drive, and it'll open up and you'll see the files stored on that drive. You can drag and drop files and save to this drive like any other folder on your computer.
Mar 06, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
How do I put my music from Itunes on the usb drive and when do I know that they are on it
Plug your usb pen into a usb slot on your computer,
open 'My computer' from your start menu or desktop,
Select your usb drive by double clicking it to open it,
Open itunes and right click on the song you would like to transfer,
click on 'show in windows explorer' This will then open up the musics file location,
have your usb drives window open in another screen and drag and drop the music file from its location the the usb drive, it will tell you how long is left of transfer, once finished transferring the notification of transferring wil then stop and close.
Select multiple music files to transfer by highlighting them and right clicking any one of them and then again completing the steps above.
Feb 22, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
How to transfer photos from nikon coolpix L21 to computer through deta transfer cable?
Using a USB lead, you shouldn't need a driver or other software. The computer can recognise the camera memory as a removable drive without actually recognising the camera as a camera. Try looking in "My Computer" for an extra drive (Under "Devices with Removable Storage") and opening that. There should be directories with picture files in them that you can drag to your desktop.
Many people find it more convenient to just take the memory card out of the computer and put it in a card reader, especially now that these readers are built into computers and printers. You can't get the pics from the camera's internal memory that way though.
Nov 08, 2010 | Cameras
Mini attache usb2.0 How do I transfer pictures in their folder from computer to mini attache
Plug the USB drive into the computer, it should install and then give you the option to explore the drive.
Go to the folder with the files you want on the USB drive.
You can either copy and paste the files to the USB drive or just drag and drop them into the USB drive
Aug 05, 2010 | Computers & Internet
I want to transfer data from my dial-up desktop, to my new laptop high-speed broadband. How?
Several ways:
1.) 4GB flash drive
2.) External USB drive (320GB or more)
3.) Burn CD or DVD on the desktop and copy to the laptop
4.) Connect them in a local or ad hoc network (not too easy)
I'm sure other expers will have more ideas...
Anyway, at the desktop, run the "Files and Settings Transfer Wizard" to gather your desktop info, such as favorites, desktop icons, My Documents, etc:
[Start]
[All Programs]
[Accessories]
[System Tools]
[Files and Transfer Wizard] [Next]
At the desktop, answwer [Old Computer] [Next]
Cintinue to answer the questions
If you have a lot of music or loots of pictures, then just transfer the "Settings Only".
After a successful transfer of the settings, run the wizard again and transfer your "Data Only"
Hope this gets you started.
Sep 18, 2009 | Computers & Internet
Transfering files from comp to comp with usb...stuck...help
take the hard drive out of the old computer and put it in the working one as a slave. you will be able to drag and drop all the files you need.
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
80 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
