Question about Creative Labs ZEN Vision:M Digital Media Player
Not recognised by pc but charges...
This is my creative vision:m 60gb (DVP-HD0004)
It goes straight into recovery mode after firmware problem image. It cleans up and formats... so it reads the hd. But when I plug it to pc it is not recognised, it does not come up as a mtp device at all. I have WMP:10 and a Acer Laptop. Tried the regedit trick... but so far nothing. Any ideas?
  • 7 more comments
  • Andre Pinho Jun 25, 2008
    Nope not recognised... but it charges. So I dont know what is possible to do...
    To make this even more clearer when I plug and unplug the device it does not make usual usb sounds of a removable disk or a ipod or a phone.
    And in the device manager nothing pops-up, question mark in any devices including usb... they remain as USB root hub.
    Updating the firmware is What I want!! but this cannot be done unless device is recognised by computer.
    Is there any way of "installing the firmware onto the hard-drive" without having to go through recovery mode? I can open the mp3 player and connect the hd through a zif to usb connector and it works...
    Nothing I can do... new motherboard?
    What about that firmware update directly through the hard drive?
    The same cable and usb port work fine with another zen vision:m but this one is the 30gb version... so drivers, cable and usb por is fine...
  • Andre Pinho Jun 26, 2008
    nope... so far.. still no go. I really reckon its a motherboard fault... I can either replace the motherboard... or fix the motherboard if someone tells me how... or my other crazy idea that might work which is if someone tells me how to install the firmware straight into a hard drive without having to go through connecting the zen vision to pc!
    I have tried it on another computer same result... when I previously mentioned a new motherboard I meant for the Creative not for my laptop...
    I access the recovery menu:
    -scandisk
    -format all
    -firmware update
    -reboot
    Note all work except firmware update as I cannot connect it to pc because it is not recognised.
    I have got the newest firmware file:
    ZENVisionM_60GB_PCFW_L21_1_21_02e
  • 92 Answers
First update the firmware..then uninstall and reinstall the drivers
Posted on Jun 30, 2008
    President:
  • 357 Answers
Hi there
1 - install Amarok from the repositories
2 - plug in your Zen (not in USB mode)
3 - Open Amarok
4 - Settings --> Configure Amarok
5 - On the Media Devices tab, click on "Add Device"
6 - Select "MTP Device" from the pull-down menu
7 - Enter a name for your mp3 player
8 - Click "Ok", "Ok"
9 - Click on the "Devices" tab on the left-hand side of Amarok.
10 - At the top left, click on Connect.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 27, 2008
  • Creative Labs Master
  • 6,487 Answers
Try this one first to make your PC recognize the zen:
Some folks have had good luck resolving USB device recognition issues like
you have by deleting the INFCACHE.1 file, which can get corrupted with bad
data and cause issues like you have. The file is located at C:\Windows\inf.
There, scroll down to the INFCACHE.1 file and right click it and select
delete. To do this, you will likely have to give yourself permission to
delete it, because of Windows built-in Security. Just right click the file,
select Properties and then click on the security tab.
Hope that helps........
    Genius:
  • 1,011 Answers
Dear Sir,
Reinstall the driver and check settings. ok. Click this link for driver software..
http://www.drivermax.com/driver/search/search_version.php?devicename=Creative+ZEN+Vision%3AM+(DVP-HD0004)&win_ver=6.0&win_arch=32
Thanks
Good Luck
"Don't forget to rate the solution"
Posted on Jun 26, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Jun 27, 2008
    Dear Sir,
    To reset the player: gently insert thin object (like a straightened paperclip) into the Reset hole located on the side of the unit, and remove the paper clip. Remove the paper clip.
    The PMC should reboot at this point. If the player continues to not respond, connect the PMC to your PC and format the unit.
    To format a Zen Portable Media Center:
    1. Connect the player to your PC
    2. Open Windows Media Player 10.
    3. Click on the File button, CDs and Devices, and then click on Synchronize.
    4. Select the Zen Portable Media Player in the Device pane (if you have multiple devices connected), and click on the Format storage media button
    1. Make sure that battery is charged.
    2. Detach your player from your PC, and ensure that it is turned off.
    3. Remove the battery.
    4. Move and hold the Power button to the Power On position and re-insert the battery to the Zen Micro. Hold the Power button until the Recovery Mode appears.
    You need to download it from Microsoft. It's a free update for any legit copy of Windows XP, and includes many security updates and enhancements to various parts of the system, including the part that deals with MP3 players that use PlaysForSure, like yours. You can get it here:
    http://www.microsoft.com/windowsxp/sp2/d...
    For more information u can see all the problems threads from this link. Check out it will be more Helpful.
    http://forums.creative.com/creativelabs/...
    http://203.211.142.198:80/srvs/cgi-bin/w..." target="_blank" rel="nofollow" http://support.creative.com/kb/ShowArtic...
    http://support.creative.com/kb/showartic...
    Thanks
    Good Luck
    "Don't Forget to rate the Solution"
    Genius:
  • 2,028 Answers
Try the download at this link, it couldn't hurt. Try saving the download to the desktop before running it.
http://www.opendrivers.com/driver/235541/creative-zen-vision-m-60gb-firmware-1.11.04-free-download.html
    Sergeant:
  • 458 Answers
Go to your USB Devices in Device manager and uninstall your USB. Then let it identify them again. They could have gotten turned of from a power surge.
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you already do this? Someone else asked you to and I did not read everything first. You can click on a persons name to get individual help and then come back here and rate them as fixya
  • 4,472 Answers
This player should still be under warranty correct? Then you will want to have it serviced under the warranty by the manufacturer.
If you have any other questions let me know.
Thanks,
Lee
    Sergeant:
  • 275 Answers
Can you access the menu of your player?
  • 1,183 Answers
WIth so many suggestions and solutions that you have got ,Jsut try two things.
1, If any other USB device like a printer or mouse or keyboard, is working with your computer. The motherboard is OK . All you are experinceing is a driver conflict( as you told , you donnot hear the usual plug in and plug out sound )
2. Disconnect all USB devices from the computer
Click START> Right click my computer>left click properties>left click the hardware tab>left click device manager >left click + next to USB controllers> Right click on all USB root hubs and delete the same
3. Restart your computer, try pluging in the ZEN
4. STill no go
5. Its a little harsh to say , but windows neeeds to be completely reinstalled , so you need to back up all your information.
Thanks
Proton
PS : HAve you tried thsi player on a different machine ?
  • Mandeep  Singh
    Mandeep Singh Jun 27, 2008
    All send and done champ, its time to buy a new player. Its hard to say being a tech .. but thats the best option. Well the CPR, failed to revive the ZEN
    You have got your hand dirty,with all the tips and trick we had to share.
    Thanks
    Proton
    Guru:
  • 859 Answers
Keep the Zen player disconnected. Boot up and open WMP. Once WMP is open plug in your Zen player. It should be recognized in WMP as a drive location you can access using the Sync tool icon.
From what I've read, it is possible, I'm not saying this happened, but it is possible you have messed the Zen bios up in your attempts to flash it.
As has been pointed out, from everything that was offered by the actual experts here, not the wannabes who would have you disassemble the board etc., you simply may have a bad player. It does happen. Too bad it happened to you but to tell you what you already know, the Zen player ain't so good. Before you ruin your chance to return it for another one. Try connecting it while WMP is open and should that fail to Sync with the Sync tool call or email Creative and get an RMA to replace it.
Worldvet
Posted on Jun 25, 2008
  • Glenn Rogers
    Glenn Rogers Jun 26, 2008
    This is not your motherboard friend. Have you tried all the USB ports on the PC, those in front and those in back?
    BTW, in your comments back please make some reference to what you tried and didn't work.
    Go to a PC your player works on and download the firmwae update and flash it from that PC. Make a backup of your firmware if its offered.
    But, try the USB ports at the back of your PC first.
    Worldvet
  • 54 Answers
When it is plugged in do the following, Go to the device manager find the player, right click and choose uninstall, click yes i want to uninstall,,, then plug it back in.. wait about 2 mins then see if its in your my computer if it is not then Right Click on "My Computer" click on manage on the left hand side choose Disk Manager, then find the drive that is plugged in RIght click on it and choose CHange drive letter and path, When you get to that page change the drive letter to somethink like "m" or "o" and it should show up , If not then send me an email at fixya@whypayforhelp.org and i will help you out
    Master:
  • 638 Answers
U hve rated som1 as best solution ,is ur problem solved?
  • 426 Answers
~Lee
    Genius:
  • 1,142 Answers
May be it can be a version issue usb 1.0 and 2.0 the zen requires 2.0 which can be tested on a different computer which should not be older than 2 years.
  • 2,071 Answers
Your zen vision cannot recognize anything what you put ,the problem is crack or cold solder joint on the socket or usb hub of your zen cercuit but it will charges ,it will charge because only two line connection compare to the line of usb it is four , one of this line is crack then will not recognize , maybe this the problem,,reheat this by using a hot air tools after reheating clean that by brushing with the use of an alcohol ,,try this option maybe of help..
  • 3,940 Answers
Try this:
Disconnect all USB devices, reboot into safe mode, open Device Manager, delete all USB Root HUBs, reboot in normal mode, let the hubs re-detect. Right-Click Each hub, click PROPERTIES, Click Power Management TAB, Uncheck the check box to let windows turn the hub off. reboot again
Connect the device, see if it is detected.
If it isn't, open DISK MANAGEMENT, and see if the drive is seen there, and if it had an drive letter conflicts.
    Genius:
  • 1,665 Answers
Some times WMP:10 causes compatibility problems. If is possible go back to WMP:9 and test it.
    Master:
  • 788 Answers
If the player doesn't complete it's boot-up it won't connect to Windows. In the recovery menu there is a reload firmware option, did you try it?
Also just to make sure it's not your PC have you tried it on another computer? A friend's PC maybe?
You could also try re-installing WMP10 in case something happened to the mtp driver.
  • 2 more comments
  • Dean Joly
    Dean Joly Jun 25, 2008
    If you're suspecting that it's your board you may be able to find another Zen on eBay with a broken screen or hard drive that you can salvage the board from for cheap.
  • Dean Joly
    This may be drastic but it may work. How about unsoldering the battery from the board in order to completely cut power for a little while. This may reset anything that may be locked up. I know that the Zen doesn't turn itself completely off all the time as my song will keep playing for a while after I turn it off.
  • Dean Joly
    Dean Joly Jun 26, 2008
    As I said yesterday, if you want to revive this Zen then I would try to find one that is being sold for parts on eBay. Make sure the one you buy has a good board, so find one with a busted screen or hard drive. You may even be able to buy just the board, but eBay is your best bet for parts like this. Good luck, and I think it's worth repairing as the Zen Vision:M is an awesome player, been using one for two years myself.
  • Dean Joly
    Definitely sound like the USB controller on the board or the firmware has taken a fit. I'm afraid that the only way I see of getting it going would be to replace the board.
  • 1,879 Answers
Does not do what it is supposed to do after the FIRMWARE update was applied. Better contact the manufacturer since their product was working fine before their update was applied.
  • 4,889 Answers
A firware update from creative should do the trick.. But it gets goofed up if you do it without reading the instructions.. you can download firmware updates from here..
http://www.creative.com/language.asp?sDestUrl=/support/downloads
    Brigadier General:
  • 3,614 Answers
Please do check the data cable your are using... does the pc give your a unrecognized usb port when you plugging the device..?
  • 3 more comments
  • micromaster
    micromaster Jun 26, 2008
    will you try this one, On the PC your are using this will be In the System Properties dialog box,
    1. click the Hardware tab and the
      Device Manager button.
    2. Next, look through the list of devices until you
      see Universal Serial Bus Controllers
    3. and click the plus (+) sign next
      to it.
    4. Double-click one of the USB Root Hub lines and click the Power
      Management tab in the USB Root Hub Properties dialog box. Click the
      Allow The Computer To Turn Off This Device To Save Power checkbox so it
      is unchecked.
    5. Click OK and restart your computer.
    Let me know..
  • micromaster
    2nd attempt:
    If you saw the big yellow question mark light up within the DEVICE MGR "OTHER" area,
    ---on your mouse Right clicked on the ZEN > Properties > and clicked on the UPDATE DRIVERS button.
    ----in here the wizard appeared -- put the ZEN CD into the drive then clicked NEXT on the wizard to proceed. If the process was made it will give a message that the driver was installed successfully..
  • micromaster
    Attempt #3 Remove Hidden Devices
    1. Click Start. Click Run. Type cmd and press OK.
    2. Type set DEVMGR_SHOW_DETAILS=1 and press Enter.
    3. Type set DEVMGR_SHOW_NONPRESENT_DEVICES=1 and Press Enter.
    4. Type start devmgmt.msc and press Enter.
    5. Click View. Click Show hidden devices.
    6. Click “+” to expand Imaging devices, Unknown devices and USB devices.
    7. if there's any USB devices and unknown devices (including grayed out
    devices)? please right click it and click Uninstall.
  • micromaster
    Hope this initial idea, will help you right there..
    Thank you
  • micromaster
    well if your are using a LAPTOP, do this:
      to it.
      is unchecked.
    Let me know..
  • 13,433 Answers
What does it come up as in device manager?
Right click my computer -> manage -> on the left side click device manager.
do you see the device there? whats the status?
  • Ekse Jun 25, 2008
    if its not recognised at all, try another computer also, then you have to send it in for service.
  • Ekse Jun 25, 2008
    it charges as the power comes from the laptop usb, but noting else is sent between the devices, only power no data. Hardware fault.
I have the same product Zen Vison W 60GB (model PMC-HD0004) and the same problem. I turns on in Recovery mode and almost all options chosen the error on screen is " Harddisk problem". I tried reload the...
Hi if your player is in recovery mode and showing the Harddisk problem screen and want and want reload the firmware the HD will need to be removed from the player and ran threw so repair software to try and fix. If it cant be fixed it will have to be replaced.
if you need any more help, parts or your player repaired you can contact me threw my repair service web page at firehouse7777.weebly.com thanks
Oct 06, 2010 | Creative Labs ZEN Vision W Digital Media...
Hard disk problem?
hi mark,I have same problem..recovery mode nothing works .. i live in australia and not sure yet who fixes it telss you about firmware download..have not tried yet..this is only something new.will try more things and post again Good luck Helen
Aug 04, 2008 | Creative Labs Zen Touch MP3 Player
Davy
What verson of Windows Media player have you got on your pc?
Find one with version 9 install the creative software and then try the reload of the firmware .Zen has problems with windows medai player 10 - 11.
Jul 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m firmware problem
Greetings,
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Jun 28, 2008 | Creative Labs Zen Vision Digital Media...
Creative Zen Touch firmware problem
This means both systems contain a bug, or cookie. If the firmware you accessed isn't applying itself to the device, this means the system itself has been corrupted. Double check with your system configuration properties on each device, and tell me whats going on from there.
Don't panic!
bananaboy101
Mar 25, 2008 | Creative Labs Zen Vision Digital Media...
ZEN VISION M STUCK IN RECOVERY MODE
im having that sme problem! even when i try 2 restart it still acts crazy! when u find out how 2 fix ur let me kno cuz really want this thing 2 start workin again
Mar 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m 60 Gb dont want to be charging
Upgrade the firmware to version 1.62.02. That should solve all your problems. Go to www.creative.com to download the firmware.
Sep 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
203 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
