Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
WD63 trips RCD but NOT old fuse-type wiring.
Have just bought a 2nd hand WD63. At the time I was told that the dryer did not work, but that is OK as I only need a washing m/c. Desperately. I saw it working before bringing it home, but in a property with the old "wire between 2 screws" type fuses.
I live in a bungalow with very new, very safe mini circuit breakers. The second the machine is turned on...the fuse is tripped. We have taken the top off the m/c (yes, turned off and unplugged) and had a good look round.
One orange wire had chafed on a bracket with wire showing...that has been mended with insulating tape....problem remains.
Please help..quickly..we need clean clothes. I am an engineer (retired, Mech. & Prod., not electrical) and my daughter has an NVQ2 in Pf'g engineering operations and electrical fitting (lighting circuits) so between the two of us. we should be able to sort this out..if pointed in the right direction.
I also have a wd63 and was running it on an extention (2core). Was having the same problem. Ensure this device is earthed as there is a large capacitor that needs an earth. Otherwise you can get a small electric shock and a rcd will pick this up straight away!
Posted on Jun 26, 2008
Machine displaying general alarm the infuser slide was very tight freed up and reassembled now turning the machine on results in an arc at the motor brushes which blows the RCD breaker.
Hi Chris
Good Job freeing it all up etc. Your 90% there
Can you remove brushes & clean and stretch a millimetre more out of brush leads to stop arcing. Or perhaps the load is to great.
I did notice you said RCD.
RCD's usually only trip when an in-balance occurs between the hot phase wire & neutral wires.
Eg... what goes in via phase wire must come out on neutral wire. Even a small millivolt trickle to ground will trip an RCD. (20-30ma)
The Residual Current Device is for electric shock Safety.
It is not the main fuse or circuit breaker.
RCD's can be a real pain when there is a slight moisture leak.
For Example.
My fridge in my Winnebago would trip the RCD after it hadn't been used for awhile. The insulation around the 10A heating element was damp & tripping the RCD continually.
So how do I bypass the RCD to heat the element up and get rid of moisture. My method was to use a stand alone generator with no RCD to power the RV.
Worked great. Once the element surroundings were dry it ran fine on the home 240vAC.
So... If you really are tripping the RCD then the problem is AC "LEAKING" to Earth. Usually Moisture.....Try a hair dryer
If it is really blowing a Fuse or Circuit Breaker then the problem is too much current being drawn in circuit.
Hope this Helps
Trevor
Apr 07, 2015 | DeLonghi Prima Donna Avante ESAM6700...
Hotpoint wmf740 washing machine tripping RCD
try this open the door and then plug it back in when the door is closed its got power so when open the power is really low if it trip after that it will be you main Bord and poss door switch but i will tell you its going to cost cheaper to buy a second hand machine if you have done what i have told you then get a call out but make sure the call out is cheap ok it could be a waste of time ok
Oct 22, 2012 | Hotpoint Washing Machines
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
Our hotpoint ctd40 condenser dryer aquarius trips our household rcd panel when you try to start the machine all the power lights are on and it does not blow the plug fuse. I have cleaned all the filters...
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
Feb 04, 2011 | Hotpoint Dryers
RCD trips after different period of time
Sounds more like a fault developing as the cable heats up due to poor connections.trip operates about 30Ma ot .03 0f an amp which is a pest but good in its own right.If you referring to one socket then remove that socket and check for any loose burning leads,Check the fusebox again for any of the above, good idea to run an independant earth around 10 mm cable to main box just in case earthing is bad..hope you get on ok.
Apr 01, 2010 | Dryers
Washer/drier tripping rcd!
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
Nov 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WM31 Washing Machine
The tripping can either be down to a short circuit drawing too much current and blowing the fuse , or an earth leakage blowing an RCD. You can eliminate the motor when it happen again , by unplugging it and see if the fuse blows (without turning the drum). Most likely is the heater , but i cannot explain why turning the drum allows it to continue. It is possible a wire is rubbing somewhere on the drum pulley , motor or casing. If the machine will immediately trip again if you don't move the drum , try isolating parts by disconnecting and then retrying.
Aug 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius wd640p
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Wd61
What ha happend is the door interlock shorted and blew the rcd. However in doing so it al blew a triac on the timer..
This is very easy to repair if you know how to get to the timer... but you also have to replace the door inter lock...
Solder a bit of wire between the connections on the timer...
If you follow the neutral wire back fro mthe door interlock upto the timer then you will see what i mean by it blowing the triac...
Jan 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
