Question about Dell 962 Photo All-In-One InkJet Printer
Put ink in my 926 printer
Hello I would like to buy ink, but i do not know how to put it in the printer. Thank you
  • terry238 Jul 01, 2008
    With the printer ON,I opened the top to reveal the printer ink cartridges (black and white on left, color on right). I looked at directions on inside cover, and lifted the latch on the left one (black and white). I pulled out the now empty ink cartridge without looking at it closely--but the new one fit back in only one way, so it must be correct.
    The label is on top (saying BLACK), and the words are facing me.
    I cannot get the top cover/latch to click back into place.
    THEN, wanting to see if the right side, the color cartridge, with light blue top, would open and close, I pushed the lever slightly and it too opened. NOW I cannot get either one to close. I tried closing the cover to see if it would all just pop into place, and it jerked to the left making the covers go down, but I got a message "black ink cartridge missing on left", so I lifted the lid and now it is just open and sitting there, turned on with the top lid up.
    Those top covers just will NOT click down.
I just bought a printer and everytime i try to install it and i get to the ink part it says that the yellow ink is not installing properly or it also says no cartagesor open the carteges and install agian how can i fix this problem
Posted on Sep 14, 2008
Thank you i resolved the problem
Posted on Jun 26, 2008
Dell 926 Printer ink refill instructions
*see the manual and follow the instructions and fill it
* contact manufacturer about details
Jul 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
926 alignment problem, just replaced color cartridge, have no manual
Hello, Here is the website to download a manual for you.
Please rate my answer, thank you.
Product Support
Sep 27, 2014 | Dell 926 Photo-926 All-In-One Printer 926...
My dell aio 926 wont print it makes the sounds but paper is blank i uninstalled and reinstalled and cleaned cartridges with cloth says there ink for 43 papges help me
Maybe it has not ink for the color you want to print or the printhead is clogged. In this last, you should change the printhead.
Thanks.
Dec 11, 2010 | Dell 926 All-In-One InkJet Printer
I just had my cartridges refilled but my printer still says low ink i used my old cartridges from dell how can i get my 926 printer to work with the refilled cartridges it will not print.
With this type of cartridge your printer will always think refills have low ink. This is because the electronics on the cartridge cannot be reset to tell the printer it is full of ink. However you should still be able to print and just ignore the ink levels. I think the problem you are having is that the electronics on your cartridge are no longer functioning. Unfortunately there is no way to fix this problem. I know you can buy refills from Cartridge World stores, but I don't know about other retailers.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Installing an ink cartridge
Just open the top and wait for the carrier to come to a stop and then take out the empy ink cartridge and put in the new one.
Aug 21, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
I don't have a Dell but we have Lexmarks which use similar cartridges. I'm guessing your color and black has a flat top. Your printer should be using a 2 cartridge system and most likely w/ 4 colors. Black, Cyan, Magenta and Yellow. The Black cartridge is a single color cartridge. The CMY (short for Cyan,Magenta,Yellow) is in another cartridge. If you don't know which one, get a paper tower and dab the bottom of the cartridge near the nozzles which are usual silver in color. If you have the color you now need a very thin needle to fit those very small holes. If your needle wont fit then you will have to enlarge the holes. To refill,you really will enlarge it anyway to inject the syringe needles in. Stick the needle into the hole as deep as you can and stop just before you hit bottom. Just approximate the height of the cartridge to the needle. When you take the needle out, use a paper towel or toilet paper to wipe off the ink. What you wipe off will be the color of that chamber. You just need to do one more on any of the 2 remaining holes. Label as you go so you know what color it is. Don't do mental gymnastics. One mistake means you either print w/wrong colors or buy a new cartridge. I'm not familiar w/ the cartridge so I'm guessing on the color you should put between 1-2ml of ink per color. On the black maybe 5-8ml. This is to be on the safe side. Don't overfill it. There's no guarantee your cartridge will print, cuz manual refills are not as good as those done on a machine. If it works you may be able to refill another 2-3 times. Manual refilling is a gamble. Just ink the ink in very slowly and be patient. take about 15-20 seconds to inject 1 ml. Hope this helps.
Nov 13, 2008 | Dell 926 All-In-One InkJet Printer
How to install hp 21 cartridge into dell 926 printer
Use only genuine cartridges with your printer. Printers these days have a built in sensor that can sense non compatible/generic/refilled cartridges and wont install them. It will only cause you more problems in the long run if you use a generic cartridges.
Best bet is to buy genuine inks..
Sep 28, 2008 | Dell 926 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
159 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
