Question about NetGear WG111 802.11g/b Wireless Adapter
Wireless wg111 802.11g problems
Hi I am having a problem with my wireless wg111 802.11g (USB)
it will connect to the router (internet)(says it has a very good signal)
but then out of the blue it will stop responding and drops the connection
if i disconnect/recconnect the adapter it then reconnects ok
any ideas appreciated
I am using the winxp drivers
i did not use the drivers that came with it(recommended)
  • jiggs-1 Dec 28, 2008
    the blue light comes on the adapter then goes out, the lights on the router checks out ok.
  • 115 Answers
Use the recommended drivers would be the first step. After that you can try to mod the adapter using WinPcap.
Posted on Jun 22, 2009
  • 1 more comment
  • MrObvious
    MrObvious Jun 22, 2009
  • MrObvious
  • MrObvious
My Netgear WG111v3 cannot connect to internet
You need to do some wireless setting on router,
Please follow steps to fix your issue
1.Please changed network (SSID)name of router
2.Reinstall adapter driver
If you follow above steps defenately your issue would be resolved
Apr 26, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Internet connection frequently drops, don't know why. Still connected to router, though not getting internet. Unplugging wireless adapter and plugging it back in fixes the problem...temporarily.
Hi
IF THE WIRELESS CONNECTION DROPS, try the following troubleshooting steps
1) connect Modem-Router-Computer
2) Open router UI (www.routerlogin.net)
3) User name : admin , Password: password
4) on the left hand side in the blue panel select Wireless settings (under Setup)
5) SSID: (user defined)
Channnel : 11 or 6
mode : upto 54 mbps or 150 mbps
Security : WPA-PSK (TKIP)
PASSPHRASE : (user defined)
Click apply
This should resolve the problem.
If the problem still persists u can try upgrading the drivers of the wireless USB adapter.
Thanks
Vineet Bajaj
Sr. Tech support Engg.
NETGEAR
Oct 31, 2009 | NetGear WNR2000 Wireless Router
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How to connect DSL internet to the second computer
You need an ethernet card, either hard wired or wireless to connect your computer to the DI-624.
Jun 13, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't connect to internet with router and wireless usb adapter
Hi,,
Did you check whether the USG adapter can work in "G" mode, read the manual of the usb adapter and check whether it can operate in "G" mode since your router is a wirelss "G" model the devices which detectes signals should also work in :g" mode, And most of the inbuilt adaters are viable with a/b/g/N type routers, so please check the manual and let me know
Thanks,
Vipin Menon
Mar 16, 2009 | D-Link AirPlus G DSL-G604T (790069265662)...
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
D Link DIR 635 router conection internet
Normally, all ruters are hubs as well. if you want to connect it as a hub only; try connecting only the ports minus the WAN port that goes to the DSL modem. In this case the router will behave just like a hub.
Nov 11, 2007 | D-Link / RangeBooster N 650 / DIR-635 /...
NetGear WG111 802.11g/b Wireless Adapter Logo
169 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
