Question about Dometic Rooftop RV Air Conditioner
Do you think it could be the fan capasitor?
What other solutions do you have ? I hate to just start replacing parts to find the problem or do you feel strongly that it is the fan motor?
  • Don Berry May 11, 2010
    What symptoms to you have?
    What kind of diagnosis have you already done?
I won't comment on this problem as there is not enough information.
I would suggest to avoid any responses from "koolbreezes" as they seem more intent on replying with insultingly inappropriate solutions, rather than actually helping.
Posted on Sep 02, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Emergency. call .please. the date is too old.
Posted on Aug 28, 2008
I have an LG front load washer and I can't start the machine, the power button will not respond. I have power to the unit because the interior drum light has stayed on. Any suggestions?
The starting capasitor on the motor could be faulty. If this happens the machine would not start running. A method to check if it is the starting capasitor, is to open up the washing machine covers and once the button is pushed - give the motor a turn by hand to see if it starts running. This should only be done by a qualified person as it is dangerous if you do not know what you are doing.
If the washing machine motor starts running, then the capasitor if faulty and needs to be replaced,
Trust this will help you.
Regards
Andre
Nov 02, 2017 | LG Washing Machines
if even after changing the capacitor the fan does not run on its own , so it indicates the weak fan motor .but before that check whether the bearings are chocked up ,sometimes even choked bearings cause this type of problem.
for any further queries feel free to ask.
thanks
Sep 18, 2008 | Dometic Rooftop RV Air Conditioner
Reverse rotatin on fan motor aire flo air conditoning model #20402077insol knew capasitor 3 tipe capasitor capasitor /hern/fan/c/
When the capacitor goes bad it can cause the fan motor to run backwards, the capacitor needs replaced.
Sep 24, 2011 | Carrier 38CKC036 Air Conditioner
Dryer not turning not sure if its heating up. Is there a reset switch.. Just hums
your going to hate me now? if the dryer motor is humming its poped its clogs on you and you will need a mew motor fitted,,,the motor has two windings in it one of them is the starter winding some use a big capasitor that holds lots of volts to give this winding a realy hard kick to start the motor turning wonce its spinning the seconed winding can keep the motor spinning if a capasitor is fitted it could be that thats packed up but normaly its the first winding burnt out,,,
now your totally bored with me,,, you just found out you hate me as well
Jun 11, 2010 | GE DCVH515EF Electric Dryer
Compressor trie to start, but don't.
Capacitor is good place to start, once you confirm you have proper voltage getting to the unit.
Jul 20, 2009 | Heating & Cooling
I replaced the blower in my 1997 Tahoe and it is still not working. Any suggestions?
,check the fuse in the fuse panal ,if good then located below the fan is a small capasitor block, it controls the dc power to the fan $15 gm part ,
Jul 12, 2009 | 1997 Chevrolet Tahoe
TV is blank and status light is blinking yellow
I think you have a powersupply problem. This model has had alot of problems with bad electrolitic capasitors through out the entire chassi assy. Because of the way the manufacture designed this unit you may be better off getting a Mitsubishi Authorised service company to fix it. If you feel confedent,
check the powersuppy for 2 electrolitic capasitors that are bulging on the top. They will be your culpirts. I believe they will be 25v 2500uf. But don't hold me to it.
Hope this helps,
Skyassoc
Jun 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Danby Silhouette DWC513BLS lower back fan noise.
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Dec 08, 2008 | Danby Silhouette DWC512BL Wine Cooler
Hitachi 55FX48B 55 in
well, if you know how to repair tv, I can provide you its service manual, just post here your email and get it.Hope you have necessary tools to rectify and check semiconductor components ;)
regards,
Sep 02, 2008 | Hitachi 55FX48B 55" Rear Projection...
Fan not working
some fan motors have a start capasitor, some have a run capasitor and some have both. if you take out the capasitors (normally in the junction box) take note of which wires go where and head to a refrigeration spare parts wholesalers they should be able to give you the right ones then replace them. this shouldnt cost any more than $20 if that doesnt work you will need to replace the motor.
Aug 06, 2007 | Friedrich SL24J30 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
