Question about Technics Audio Players & Recorders
My Technics DV-170 shows F61 Error when i try and turn it on?
  • 4,234 Answers
That is a protection indication. This means that the output amplifier section has a problem that was detected and a shutdown occurred to prevent further damage. I don't have a listing for your model, so I can't provide you with too many details, but look for a large black IC attached to a heatsink. That should be the output amp pac. If there is not one, there should be 4 3-legged parts (transistors) and one or more of those may have failed. I have also seen cases where a voltage regulator that supplies the driver circuits has had bad connections thereby shutting down the driver circuit.
Keep us posted.
Dan
Posted on Jun 25, 2008
Is not work it is show f61 what dos this mine and how to fix it
The F61 error on Technics audio equipment will depend on the type of unit. However, it could be a problem with the power amplifier IC or with the cooling fan. (If it's the fan, you might be able to clear the error by pressing and holding the power button until the fan starts to spin.)
Please add a comment with the model number of your audio equipment for more information.
I hope this helps.
Apr 05, 2015 | Technics Audio Players & Recorders
I have a technics stereo but f61 error on it how do i fix it
F61 is the error code for an amp problem. It may need an amp IC replaced, or, if you're lucky, the may just be bad solder connections on the amp IC's and regulators that are on the heatsink. Most of the technics receivers had an access panel that can be removed from the bottom of the unit, and then you can visually inspect for any bad connections. Check anything that is on the heatsink as these were the biggest problems for this line of receivers.
Dec 18, 2012 | Audio Players & Recorders
My technics hi-fi separates sL-EH790 is not coming on just saying f61 then going off
Hi Shelly,
"F61" is an error code for short and/or overload detected by the processor upon self check.
First thing you have to try to eliminate this kind of symptoms is by disconnecting all of the inputs and speakers connected from the unit then turn it on without them. Let me know if the symptoms still persist...
Jdvillanueva
Oct 22, 2011 | Technics Audio Players & Recorders
Stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Oct 15, 2009 | Audio Players & Recorders
Technics F61 error, can you please tell me what this means?
F61 is the "shorthand" for protection mode for Technics units. Either the regulator IC or the output AMP-PAC IC has failed. Expect a parts cost between $40 -$100 for the repair depending upon which IC has failed.
Dan
Jun 19, 2009 | Technics Audio Players & Recorders
Technics dvd stereo sound processor sh-dv290
The F61 is essentially a "protect mode" mesage. A problem was detected and the unit shuts down. This translates into either the amp pac being defective ($approx $95 for part) or a defective regulator circuit (less $$). In either case, the repair is not the simplest to do. Check around for a Panasonic authorized service center and call to get an estimate. This is a relatively common fault, so you should be able to get a ballpark repair cost.
Dan
Jan 29, 2009 | Technics Audio Players & Recorders
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Dec 05, 2007 | Samsung HT-DS610 System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Technics sd player
hi i have got a technics sl-eh760 an when i turn it on it works but when i press the open button it comes up with error can you help me out
May 14, 2007 | Technics SCEH790 CD Shelf System
CODE F61
F61 tells you its a power source problem according to the manual. to all F61 error it is very likley that the str470-050a reg legs desolderd and have broken away from the main body of the regulator giving you the f61 and shut down.
Jan 12, 2006 | Technics SCEH790 CD Shelf System
219 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
