Back to:
Tags:
Brother MFC-8440 All-In-One Laser Printer
Paper Jam with no access to clear (by 5 users)
posted by promocon on Jun 25, 2008
the paper is jammed in the back roller, inside the fuser cover. However, I cannot access the paper, as it's all scrunched against this roller. I'm searching for a way to release this roller from the fuser unit and NEED some help, as this is our only printer/fax machine!
Please let me know if you can help. my direct email is bobstep AT optonline dot net
thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by cdailey, posted on Sep 16, 2008
Pieces of paper are jammed and I can see it. I can't find a way to open so that paer pieces can be removed.
Comment by ancil, posted on Aug 30, 2008
HP Officejet Pro L77780 All-in-One. Paper tore when attempting to clear jam. Can still see paper but cannot reach paper to clear because of black plastic part. Looks like a defect in design. Should be a release button somewhere to enable you to remove the paper if it can only be removed from back.
Comment by lhallhome, posted on Aug 26, 2008
The paper is jammed under the roller at the front door. After removing the paper a small piece of paper was jammed. Finally getting the paper removed, the middle of the sheet of paper gets crinkled and stuck any time we try to make a copynow. It makes a weird sound as it grabs the sheet of paper to print.
Comment by ashiq_munis, posted on Aug 25, 2008
Can you Help with these Printers problems?
front cover broke, where can i get a replacement
I have tried two new high capacity toner cartridges and...
Fax machine is set on manuel and can not receive fax,...
This copier is showing the message.:: Maintenance 7 on...
Hi, When trying to fax from the tray, the mechanism to...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
