Question about Uniden Lands Phones
I am getting disconnected half way through a call
  • Anonymous Aug 20, 2008
    new batteries dont hold charge
  • 161 Answers
That could be a battery problem, a network problem, or a phone factory defect. Contact your network provider toll free for troubleshooting.
Posted on Jun 25, 2008
How can i reset the fault light on dash
Try disconnecting the battery for 10 minutes, then reconnecting.
Aug 25, 2016 | 2007 Toyota FJ Cruiser
Disengaging 100 Meg Iomega Zip drive most days
Is better to disconnect it completely if not use that often. If the drive is half way disconnected it might be still getting power, that is why you hear the motor working.
Apr 25, 2008 | Iomega Zip 100MB (31714) External ZIP...
No water being dispense into ice maker. It's doing it usual dumping & everything . The cold water dispenser in the door is working.
Probably a bad inlet valve on the lower back where the house water line hooks to the refrigerator. Its a 2 part inlet valve. Half feeds water to the dispenser and half feeds water to the icemaker. You can't change half--need a complete valve assembly. Not hard to change. Disconnect house line---unplug 2 wiring plugs (4 wires total) and disconnect 2 plastic water lines. Reverse to install---don't get wiring mixed up or reversed.
Jun 16, 2015 | Refrigerators
How does the quick disconnect release from the filter
I assume it is the fuel filter. Buy removal tool. It has 2 half rounds which fit over the pipe and slide into filter. push in and pull out pipe.
Apr 05, 2014 | 1996 Pontiac Grand Prix
Tv has white horizontal lines across screen you can still see what ever your watching on the screen its just distorted becuase of the lines if i disconnect the 3 ribbon cables on the top y buffer i...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 15, 2017 | Philips 50PF9830A 50 in. Plasma HDTV
Half screen clear picture other half dark picture
This looks like it is caused by the T-CON board. This board supplies the signal to the LCD screen.
IF you knowledgeable in electronics repair or have a friend with knowledge/skill you can disconnect the T-CON cable and clean the contacts and reconnect it. Sometime disconnecting this can make the picture change for the worse so you may have to disconnect/reconnect several times. Be careful because of the fine contacts.
Jan 24, 2011 | Audio Players & Recorders
How do I replace the clutch of my 2007 1200 GS Adventure?
Is your clutch slipping?? Is there an oil leak between the engine/trans?
Replacing the clutch on a R1200GS is a bit involved unless you are very mechanically skilled. You basically split the bike in half to remove the transmission and gain access to the clutch. You need a means of supporting the front half of the bike under the engine while you remove the back half of the bike. Disconnect electrical harness from the rear, disconnect brake lines to the rear of the bike. remove throttle bodies etc. takes 2-3 hours for a skilled mechanic to get the clutch out, then 4-6 hours to put all back together again CORRECTLY!
If the clutch is NOT slipping, I would suggest removal of the starter motor on the lower LHS of the engine/ trans. and measurement of the clutch disc before you start the work of disassembly
Oct 06, 2010 | 2007 BMW R 1200 GS Adventure
PS3 Madden 09 runs slow in middle of game
You might wanna get disconnected from the internet in any way.
Go into the settings and network settings to get disconnected.How long do you play anyway?
Jan 17, 2009 | Sony Playstation 3 (PS3) Console
External Hard Disk problem to connect
Try connecting in safe mode with networking and then check if it doesn't disconnects then scan your system with mcafee 8.5i anti virus.
Perform a checkdisk on your usb drive
Please rate this fixya
Jan 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Water running out the bottom
I also had this problem, and also took the bottom off mine and found that a hose that connected to to the water level tube had become disconnected. The only thing I would add is that in order to get the bottom off you need a Torx internal tamperproof pin (6 lobe) screwdriver to take the 5 screws out of the bottom.
Jan 09, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Lands Phones Logo
82 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
