Question about Palm Treo 680 Smartphone
Music ringtones hi i know this sounds really silly but i can't get my palm 680 to play my music as ringtones only what the phone has on it how can i do it... thank you
You can't play any ringtones aside the ones that come with the phone or with a software you have to buy. I did not find any software that allowed me to play popular music ring tones. You can download one of these softwares from the palm website and try it for free. The ringtones are similar to what the phone already has, not anything that is playing on the radio
Posted on Jun 29, 2008
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    How do I transfer my music ring tones from my laptop to my Palm Pre cellphone
    The ringtones have to be in .mp3 format. If they are in .wav they wont work. First, connect your phone to your computer with the usb charging cord that came with the phone. Secondly, a notification should pop up on your device allowing you to select usb mode or just charge. Select usb mode. Then go to my computer on your computer. you should see a directory that says Palm Pre. enter that. Then open up a new explorer window and find where you put your ringtones. Select them all and right click and click copy. Then go to the first window, and right click, then click paste. remove the phone when its done transferring. When you go to sounds and ringtones settings on your phone, you will see when you are selecting a ringtone a little button in the lower left hand corner. Tap it. this will allow you to add files to your ringtones. After you tap them to add them to your ringtones, do a back swipe. Then tap the ringtone you want to use.
    Mar 29, 2011 | Palm Pre Cell Phone
    How do i transfer music from my computer to my palm treo 680? i have and sd card in my phone but it only allows me to download pics
    format your sd card using your treo 680. then you insert your sd card to your laptop or into a card reader so you can transfer music files from your computer. create a folder to the main directory of your sd card and then rename it to "AUDIO". you may now save music files to that folder.
    you can now play music files to your treo 680.
    Sep 10, 2009 | Palm Treo 680 Smartphone
    I cant set my sounds as ringtones!!!!!!!
    u set the ringtone from mutimedia>sounds,ussally while playing the will be option "set a ringtone" not from digital audio player,directly from sounds.
    motorola does not accpet viruses infected files or their phone must be trying to send virus attachment or ur phone memory will be full.
    Jul 09, 2009 | Motorola Mobility RAZR V3
    Htc tilt no sound no ring
    go into settings and on first page youll see phone, tap this and assign a ringtone also look at sounds and notifications in this folder also you can test them playing from here
    Feb 24, 2009 | HTC TyTN II Smartphone
    Palm treo
    THE phone's Headset Plug is stucked. Try to plug and Un-plug the headset many times for it will release. Best, Play a Music and try this on so when you haer the sound coming from the phone, it means it works
    Jul 29, 2008 | Palm Treo 680 Smartphone
    Z310i no sound plays for ringtones
    step 1.take your mobile phone in your right hand
    step 2.switchoff your mobile phone.
    step 3.take a bucket full of water.
    step 4.drop your mobile in the water and keep it for 5 mins.
    step 5.takeoff your mobile from water.
    step 6.clean it with your pant.
    step 7.just switch on your mobile.
    step 8.you will find a great change in your mobile
    Jun 01, 2008 | Sony Ericsson Z310i Cellular Phone
    Palm treo 680
    i need to know how to block private incoming calls on my palm treo 680
    Apr 22, 2008 | Palm Treo 680 Smartphone
    Ringtones
    Did you create a folder for the Ringtones? if you did, make sure you have it on 2 (sounds)...go to Menu, Press 7 (my stuff), press 2(sounds) open your Ringtone folder and Voila!!! der they r...press d options (dont play the song, just highlight d ones u want to set as a ringtone) press 2...n der u go.
    Reps are appreciated :)
    Nov 28, 2007 | LG Shine KE970 Cellular Phone
    Setting ringtone
    Here are instructions for setting the ringtone on a Palm Treo 750 running Windows Mobil 6.0 Professional
    To change the ringtone do the following:
    1.Go to Start and select Settings
    2.Select "Sounds and Notifications"
    3.Go to the "Notifications" tab listed along the bottom
    4.In the Event field either press the middle button or use your stylus to see the drop down menu.
    5.From the menu choose whichever option you want to set the ringtone for. i.e. Phone:Known Caller or Phone: Unknown Caller
    6. Once you have made your choice go to Ring Type. Here you want to access the drop down menu so you can chose how long the ringtone will sound.
    7. Once you have made your choice go to Ring Tone. Access the drop down menu again to cycle through the different types of ringtones. If you have music on your phone you can also choose this as your ringtone instead of having to purchase them but first some steps have to be taken in order for the music to be seen in the drop down menu. I will put that at the bottom of this solution just in case it's needed.
    You can use this method to set ringtones for other things such as incoming email, messages and reminders. With Messages Emails, and reminders you can also select music that is already on your phone but I have not been able to do the same with smaller things like "Connection Disconnected".
    Here are instructions for making music on your phone into a ringtone.
    You may want to have an expansion card for this but it can be done without one. If you are not using an expansion card and would like to make all of the songs on your unit into a ringtone you may have to delete the music files after adding them to your ringtones.
    In order to make your music available for choice in ringtone all songs must be in the "My Music" Folder prior to beginning.
    Begin by following steps 1. and 2. from above then:
    3.Select the "Manage" tab
    4.Select Menu then select Add
    5. For this part I find using the stylus is simplest. On the top left of the screen push the down arrow found under the words "Select a Sound"
    6.From this drop down menu select "My Device" then click on the "Music" Folder
    7.Once there Highlight the song you would like to be a ringtone then click "Select"
    All done Now the music on you phone is a ringtone. Ringtones made this way can be deleted anytime simply by going into the "Manage" tab again, highlighting the song you wish to delete, Selecting "Menu", Then selecting "Delete"
    Nov 22, 2007 | Palm Treo 750v Smartphone
    Palm Treo 680 Smartphone Logo
    80 people viewed this question
    Top Palm Computers & Internet Experts
    Michael Vincent Cruz
    ray gallant
    Raj Patel
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
