Question about Sharp 32C-240 32" TV
Sharp tv 'LC46XD1E' sleep timer
My sharp tv lc46xd1e regularly changes channel and banner appears saying sleep timer has done this. How do I switch off the sleep timer?
  • Anonymous Sep 09, 2008
    When TV is switch on, it goes into the timer mode
5 Suggested Answers
SOURCE: Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Posted on Sep 22, 2007
SOURCE: sharp tv changing channels
Well, the only thing that seems to be working so far is to plug AV cables into the "input 2" ports (on the front of TV). I plugged in my PS2, without turning it on. It has not switched at random since (about 30 minutes - it had been switching off and on for the past 2 hours). Anyone else have similar success?
Posted on Nov 28, 2007
  • 15 Answers
SOURCE: One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Posted on Jan 25, 2008
ScottSwan
  • 33 Answers
SOURCE: No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
SOURCE: Sharp 32f540 switching input channels
Ladythree,
the problem for your unit is the manual button switches. In the long time it wasnt used. it got stucked and somewhat rusted. This problem can best be addressed by replacing the buttons switches(tac switch).
this should solve your problem.
chris
Posted on Mar 29, 2008
Does this tv have an option to set a timer to turn it on?
spec sheet here
http://files.sharp.ca/Downloads/ForHome/HomeEntertainment/LCDTVs/SpecSheets/LE650_SERIES/LE650%20Series_Spec_Sheet_rev.pdf
It does have a Sleep Timer as most do. Not many people want the television to switch on when they are not at home?
Direct Button Operation
INPUT .......................................................... 20
Changing Channels ...................................... 20
Changing Volume ......................................... 20
MUTE........................................................... 20
Sleep Timer .................................................. 20
manual is here
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/mon_man_LC70LE640U_LC60LE640U_LC52LE640U_LC70C6400U_LC60C6400U_LC52C6400U_LC80LE633U.pdf
Sep 22, 2015 | Sharp AQUOS 60" 650 Series LED HDTV -...
TV keeps turning itself on and off
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 14, 2015 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
HALF SCREEN BLACK
Drop it from an extreme height and that's the problem fixed a complete black screen all over
Sep 02, 2012 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
SHARP LC 46XD1E LCD TV
the service menu can only be accessed with a "service remote" only available to certified Sharp service techs... special training and $350 required to become one... contact sharp for more info or find a repair man locally if you dont want to become one yourself... the training is a lecture
Jul 04, 2012 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
Occasionally we get a message on screen saying that thepower will be switched off in so many seconds and to press any key to stop the count-down. Please would you advise us?
Hi there, it sounds as though the sleep timer has been set. Look through your menu's on the tv, on my 26" sharp aquos, its in the setup menu under timer fuctions.
Hope this helps
May 08, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Re-program a Sharp remote control for LC-46XD1E
Are you sure it is the remote that has stopped working? If you get something like a camera phone and put it over the LED on the remote and press the buttons (with the phone in camera mode) the camera will pick up the infered signal from the remote. This will rule out if it is the TV or remote.
If you get the infered signal then your TV is faulty (possibly a main pcb fault) if you dont then it is your remote. Which as far as I am award you can not reprogram, but you can get them from places on the internet (search on google) for a couple of 10 pound.
Jan 30, 2010 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
MY screen (sharp lc-46xd1e) has no image only lines, as if the
Not likely. The LCD Panel is fragile and would not have to take a front impact to get that kind of fracture.
I'm sorry for the bad news but only replacing the LCD Panel will fix it.
I hope this helps,
Skyassoc
Oct 22, 2009 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Sharp 32C-240 32" TV Logo
309 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
