Re: For using symantec winfax pro, what are the...
Fax modem class 1, class 2, or class 2.0
fax line (analog regular phone line)
windows xp or earlier releases of Windows http://www.getfaxing.com/winfax
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
this happens when your fax modem has changed, or the fax modem driver name has changed in windows. This usually requires you to reconfigure the modem in WinFax. www.getfaxing.com/winfax
Unplug your All-In-One Fax printer if it is connected in the same line as WinFax, or disconnect the telephone line. Otherwise, your All-In-One is receiving the fax , not WinFax.
If WinFax is asking you to select a type, its probably because it didn't detect a fax modem.
Make sure your modem works in Windows first If you can dial out of your computer using your cell phone using Windows, and your modem supports fax class 1 / 2 / 2.0 , then it MAY work.
configure your fax to answer later (maybe after ringing 10 times) and configure the winfax to answer before (something like ringing 5 times or less)
the problem here is that the fax answer and start receiving the fax and the winfax receive the fax signal at same time. check the winfax maybe you have the half part that the fax modem not has printed stored in winfax, maybe.
as I said, your better choice is removing the fax modem. even configuring like I said before, maybe the two continue to try to receive the fax at same time.
