Audiovox 32in flat screen t.v.
Takes 30 min to warm up when u turn it on . then the color is not right anymore, had it in a t,v. shop for 5months he could not fix it.
  • 4,234 Answers
This sounds like a digital processing problem. You state it was in the shop, was this an authorized service center? Is it still under warranty? I assume it is not. This will not be an inexpensive repair. The replacement board will be in the $100s. Try calling Audiovox directly (the number should be in the owner's manual) and request some help.
Keep us posted.
Dan
Posted on Jun 25, 2008
  • 24 Answers
Then in that case you wil need to either replace it or if it has a garantee and it has not ran out get it replaced.
Sony pfm-42x1 flickering screen when turning tv on
OKAY I found the Problem!! Bad Caps Compositors. I Proved this in 2 ways. First I took off the Back(always make sure the TV is UNPLUG) In the photo above I put my finger on the capacitors. I found some that where NOT FLAT ON TOP(You can kinda see in the photo too). I could feel a little nipple on top.(Some times you can see if their busted open but not in this case) so I felt them and the bottom right and top left area in red in the photo where not flat. I took my dryer(My wife really) and warmed them up for about 2 minuets each then another minuet rotating back then forth. I leaned the t.v. up to lean on the frame and plug it in. I continued warming the capacitors up and in about 2 Min the T.V. has stop blinking. Much better then the 20-30 min. So the hunt for the Capacitors is on. It will be some work to get the boards out. If everything is done delicately The Soldor job is easy for me. I am going to buy the 8 but replace 1 board at a time until the TV works and put the other on the side for next time or put them up on E-bay. I hope this helped Please like if this helped you. ea0a96a3-fb82-4ec0-89f4-76b4080e9c6e.jpg 1b190ebd-5d69-4553-a009-840d29ab4c87.jpg ab9b51d0-6e1d-4cce-b822-e80d0fde9163.jpg
Oct 13, 2013 | Sony PFM-42X1 Plasma TV
Fuzzy screen
Had the same problem used weather stripping to secure the tape carrier package to the screen bond there is no real way to fix this only to use pressure to keep the TCP against the edge of the LCD these Samsung had a bonding issue ,the repair shops will replace the whole panel
Feb 05, 2012 | Toshiba REGZA 46RV530U LCD TV
I purchased my Sceptre 32in tv in 2006. In the past 6-8 months I've noticed that the television has been taking extremely long to show the SCEPTRE screen after it has been turned on. Today I turned the...
The tv that take a long time to turn on.The cause is the tv power supply board,it not giving the tv the wright power voltages anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 27, 2010 | Sceptre X32BV-Naga 32 in. LCD TV
I TURN MY TV ON IT SAYS audiovox for 30 sec. then CUTS OUT
one of two things puffy caps in your power
supply , or your inverter is failing cap are easy fix , but inverter not try shop jimmy .com
Sep 19, 2009 | Audiovox FPE2306 23 in. LCD Television
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
My screen on my syntax turns pink after it warms up for 10-20 min
it could either be a lcd control board or a main bd causing this problem
im not sure you can get either part as of now
Feb 09, 2009 | Syntax LT27HV 27 in. LCD HDTV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Polaroid, 32in, HD LCD.
32 flat panel polaroid will not turn on
Oct 02, 2007 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
