Question about Sunbeam Classic 3964 Iron with Auto Shut-off
Iron no longer has steam function
My iron is about 3 months old and all of a sudden it no longer steams. I go through the proper procedure as I have in the past and the water just sits in the well and doesn't produce steam. The iron does get hot. I was thinking of throwing it away.
Any suggestions?
    Sergeant:
  • 260 Answers
If you are using tap water then the hardness of the water could cause the problem. You can usually fix this buy running vinegar water through the iron once or twice like you would a coffee pot.
If you have been using distilled water then you probably need to replace the iron.
Posted on Jun 25, 2008
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
    Hello :
    1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
    2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
    3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
    4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
    PLEASE RATE !
    Apr 18, 2010 | Euro-Pro Shark GI490 Iron
    No spray
    Return it to the purchaser and they will replace it or return to the manufacturer. Be sure to take your reciept with you
    Sep 16, 2009 | Euro-Pro Steam Generator EP8001 Iron
    My Rowenta Professional Iron stopped the steam function button.
    You may consider buying annew one Wallmart usually have a range of irons some under $10.00
    Jun 10, 2009 | Rowenta Professional DX8900 Iron
    MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
    Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
    Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
    Please remember to rate this solution.
    Feb 19, 2009 | Rowenta Professional DX8900 Iron
    Just a few months old and stopped steaming, steams frowater entry
    I have taken one of these completely apart and found it is glued together except for the platinum plate on the bottom. It is held on by circular lock clips and will break w/o proper tool. I see no way to repair these and the cost of sending in will probably be as expensive as a new one. I have seen them at Lowes and TuesdayMorning for about $100.00. Have tried to get a repair manual from Rowenta-good luck!
    Nov 15, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
    Sunbeam Classic 3964 Iron with Auto Shut-off Logo
    271 people viewed this question
    Top Sunbeam Irons Experts
    Tony
    Henry  Thomas
    Henry Thomas
    Wayne Fellows
    Wayne Fellows
    Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
