Question about QVS NetStar (UPS650A) UPS System
NetStar 400 UPS Cable
Hello, I've got an UPS with the following written on it:
NETSTAR on the front and Netstar 400 as the Model on the back. Although it look exactly like the QVS NetStar UPS650A, I cannot find QVS or UPS650A written on it, not even inside.
1st Q: I'm looking for the wiring pinout of the serial cable to connect it to my PC, so that I can make one up, please!
2nd Q: Will it work with WinXP's UPS power program?
Thanks in advance,
WalkTall
  • 7 Answers
SOURCE: New battery will not recharge
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Posted on Jan 25, 2007
How do I open the ups netstar 1200
Torx screws on the underside.
Carefully break sideways ...
Jan 10, 2015 | Computers & Internet
How do i replace the battery on a netter xt 1200
Turn off power and unplug from the mains. Make sure the power button on the UPS is turned off. Remove the screws on the underside and remove the front cover. Pull the top part of the UPS upwards. Look for the battery connectors and remove the positive and negative cables from the battery. Install a new battery of the same value. Fix the positive cable first then the negative. Test it and close it up.
Jan 10, 2015 | QVS NetStar (UPS650A) UPS System
5kva ups dosn't switch on (ups is dead condition) main mode&bettery mode please any one ideas
Hi Santhosh,
Have you checked to see if the batteries in the UPS are any good? Most UPS systems refuse to turn on if dead batteries are attached.
Reply or call if you need more help with this -- 407.380.9200
Sep 28, 2013 | QVS NetStar (UPS650A) UPS System
I have Numeric 1000 Hp Digital Ups .now i have a problem With it .Always it is giving short beep sound, and displays shows "Warning 22".Battery back up is also not giving. During power failure instrument...
Replace the batteries in the UPS - that's your problem. Everything should work after that :-D
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 24, 2013 | QVS NetStar (UPS650A) UPS System
The ups is shutting down immediatly ,once the AC power is off
thats a dead UPS... battery is bad now... you probably need to have it changed...
Jul 09, 2009 | QVS NetStar (UPS650A) UPS System
Numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
How to charge UPS
iam having numeric digital 600-ex-c ups but it making sound when we on the ups .... how i can charge it?
Jun 05, 2008 | QVS NetStar (UPS650A) UPS System
Dec 19, 2006 | QVS NetStar (UPS650A) UPS System
QVS NetStar (UPS650A) UPS System Logo
121 people viewed this question
Top QVS Computers & Internet Experts
Bill Boyd
Power & Systems...
Power & Systems...
Justin
Justin
Are you a QVS Computer and Internet Expert? Answer questions, earn points and help others
