Question about Intel Motherboard
Pioneer dvd-rw dvr-k17 problem
I have VGN FZ290 (sony customized model notebook). Now the problem is that it show no dvd drive on MyComputer but shows yellow triangle on Device Manager as"YX3808M SVO066H SCSI CdRom Device".
OS is vista premium
pioneer dvd-rw dvr-k17 ata
Please assist how to fix the problem. The drive was working properly before
Thankyou in Advance when you go to divise manager there's an exclamation mark ,I need to remove the upper fillters and the lower ones from regedit (windows Vista) 3
Reset the bios
Posted on Jun 25, 2008
I hav VGN CR24G/BNow the problem is that it show no dvd drive on MyComputer but shows yellow triangle on Device Manager pioneer DVD-RW DVR-K17 ATA device and shows error code 39 in the device status....
Try right clicking on the triangle and choose to update driver if you have the internet choose use internet this one time option, and see if it can find an updated driver.
Unplug pc from the mains and take the side panel of, check the cables are in correctly, also check the drive is set to the right jumper setting usually master.
Also check in the bios to see if you have raid capabilities, it would be worth disabling it. It is for hard drives not for removable devices.
Jan 24, 2010 | Pioneer DVR-107D DVD±RW Burner
dera ingrid 61
Please reinstall the drivers for the both of the problems,if you dont have any cd then plz visit the manufacture website and download the drivers, after installing the problem is not solved then plz try with another drive,if the problem persist then try by reinstalling the OS
Apr 25, 2008 | Pioneer DVR-107D DVD±RW Burner
I have a sony vgn cr220e that comes with a pioneer dvd-rw dvr-k17 ata optical drive and had original vista home premium OS, but someone fomat hdd and installed windows 7, now i am having problem reading...
You should have a start up disc for the thing that will restart the drivers or go the the Pioneer website and they posslbly have an upgrade or even on the microsoft website just look if not reformat the hrddrive with the original os if it wasnt bootlegged
Jan 18, 2010 | Pioneer DVR-107D DVD±RW Burner
My DVD Drive Showing Every cd/dvd as empty as it is not empty...
wel the only option 4 u is to install linux or
format ur by C drive usin linux NTFS format!!
Mar 31, 2009 | Pioneer DVR-107D DVD±RW Burner
it's windows problem.
basically you need to edit (delete) registry.
follow this step from microsoft.
http://support.microsoft.com/kb/314060
Aug 05, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17 ata device
no issue shut down the laptop reset the dvd i mean reconnect it and restart it will automaticaly pick up and if not then thee is a prob wd win they might be corrupted
May 20, 2008 | Computers & Internet
This sounds like you have a Virus or Some other type or Malware that has corrupted your drivers. Please Scan with Avast (http://www.avast.com/), Spybot S&D(http://www.safer-networking.org/), and Adaware (http://lavasoft.com/) all of witch have free versions.
Also it may be that your driver got corupted some othere way if it still does not work try roleing back your driver or updateing it.
Thank you,
Rel
P.s. if that does not work please come back and make sure you give the info that you have
scanned with the above and if you do not reply in this question then make sure you include all
that info with all the info you have already put here. Good Luck!
Hi
Right click on the driver and then click Properties.
On the properties screen, check the device status and then go to the Details tab at the top.
If the details screen shows any errors or problems abt anything other than drivers, then follow the steps below to delete the upper and lower filters from registry.
Step 1: Back up the registry
  1. Click Start and and in the Start Search box type in REGEDIT and hit Enter .
  2. From the Registry Editor window, perform one of the following depending on the operating system:
Click File and then click Export File.
  1. The Export Registry File window will be displayed. Save In: should be set to the Desktop . Next to File Name: provide an easily identifiable filename like “Full Registry Backup”. In the Export Range portion of the window, make sure the radio button next to All is selected. Click Save to save an exported copy of the registry to the desktop.
  2. Step 2: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
  1. With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
    or
    • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
  2. Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
  3. Click the plus sign [+] in front of Control.
  4. Click the plus sign [+] in front of Control.
  5. Click the plus sign [+] in front of Class.
  6. Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  7. With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
  8. Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
  9. Exit the Registry Editor
  10. Restart the computer. The optical drives should then be recognized and available for use.
Feb 25, 2008 | Computers & Internet
This worked: thanks to riozebratubo
delete the entires in regedit.exe
"UpperFilters"
"LowerFilters"
They're inside:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
-uninstall the driver
- restart
Vista is searching for existing drivers -> done
Feb 05, 2008 | Pioneer DVR-107D DVD±RW Burner
If u are using winxp try to restore your OS to one day before it was uninstalled
Dec 03, 2007 | Computers & Internet
Intel Motherboard Logo
144 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
