Question about Acer TravelMate 4010 Notebook
Display Screen The display screen shows only 3/4 of screen from left to right. It was working fine until my daughter was using it and and all of a sudden the size changed. Any ideas if she could of hit a key or combo of keys to cause this. I have checked everything. I just want to make sure before I try to have this laptop fixed.
  • 2 more comments
  • taylor1317 Jun 25, 2008
    Is is the right side screen. 3/4 of screen is displaying from left to right and 1/4 right side is missing. It could be that the screen just when bad. I looked at the cable connection that supports the display and saw no problem. Just could be a bad lcd.
    Missing out.
    Thanks
  • static128 May 11, 2010
    Has the screen actually stretched or is there a part blanked/missing out?
  • 137 Answers
Uninstall and reinstall the video driver. Open devmgmt.msc and go to video driver properties and uninstall. reboot windoze and the driver should automatically get installed. If not go to manufacturers website or insert driver disc.
Posted on Jun 25, 2008
    Problem Solver:
  • 5 Answers
It would most likely be a damaged screen if the left side of the screen looks no different to normal. LCD screens tend to go in horizontal or vertical patches if there is a problem with the internal connection to the LCD.
  • static128 Jun 25, 2008
    BWT this a much better indicator is if the problem happens during the initial boot up of the computer (ie the first few screens you see after pressing the power button)
  • 326 Answers
She might have changed the display settings, right click on your desktop and go to properties, go to the settings tab and change the screen resolution there. might not be the problem but worth a look, i had something simular when my daughter messed with my pc.
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • Oct 19, 2011 | Kenwood Car Audio & Video
    I need to have the resolution set at 1440 X 900 for best viewing. I don't have a clue how to do this. Thanks.
    Hi
    Please do the following
    1) Switch on your PC
    2) Right Clickin the middle of the dekstop and click on properties
    3) This will open a display properties window, at the top there will be a tab called settings
    4) In this windows half way down there will be a option entitled screen resolution, this slider can be pushed to the left or right push to the left until the figures at the bottom read 1440 X 900 pixels
    If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
    Feb 17, 2010 | eMachines E17T4W 17" Monitor
    I have a blank, black screen, irrespective of the input (cable, dvd, wii). The menus, however, come up fine and the audio is working fine.
    Your screen is showing a black picture because the closed caption function has been activated. When the closed caption mode is on the screen will display an 80% black picture.
    To turn off the closed caption and regain a full screen please follow these steps;
    1) Press the Menu button
    2) Use the up and down arrows to navigate to Closed Caption
    3) Use the right or left arrows to select it.
    4) Use the right or left arrows to select OFF
    5) Use the up or down arrows to select Finish
    6) Use the right or left arrows to save the settings and exit.
    You should have your full screen back now minus the annoying black box.
    If this solution has helped please do take a moment to rate it.
    Thanks for using FixYa
    Dec 25, 2009 | JVC AV-32D305 32" TV
    Change name on a Nortel M7324
    1. Press the Rls button then ** FEATURE 266344 (CONFIG)
    2. Password is 23646 (ADMIN) The display reads Terminals & Sets
    3. Press SHOW ans enter the Extension for which you want to enter a name.
    4. Press SHOW, again
    5. Press the NEXT key until the display reads NAMES at the top left corner.
    6. The bottom right corner reads CHANGE, press the far right soft key.
    7. To move from one letter to the next use the far right and far left soft keys or the # key.
    8. When you are finished Press next.
    9. Press the HEADING key to get back to TERMINALS & SETS and start again!
    Navigation Keys: Line 1 = HEADING Speed Dial = SHOW
    Line 2 = BACK Last No. = NEXT
    This can only be done from the main handset and only one at a time. The Soft Keys are the three small buttons right bellow the screen.
    Jan 28, 2009 | NorStar M7324 Telephone
    Laptop computer connected to projector.
    When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
    But once you find your dual display options you will be able to change it to make both displays the same
    Jan 21, 2009 | Dell Latitude D600 Notebook
    The display screen has turned black
    When you connected the external monitor thto the laptop did it display?
    If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
    Typical use is:
    • 1 press = external monitor
    • 2 presses = laptop and dual monitor
    • 3 presses = just the laptop screen
    Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
    Black striped down left hand side of display
    Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
    I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
    let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
    L8r
    Nov 13, 2008 | HP w19 19" LCD Monitor
    Screen problem
    Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
    Feb 23, 2006 | LG Flatron 995FT 19" CRT Monitor
    Acer TravelMate 4010 Notebook Logo
    101 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
