Canon np 6030
I get "E224 turn off and back on" message when turning on machine. I checked error codes and it says "blank shutter problem". I'm trying to fix this machine for a local christian outreach program which does not have a lot of money to spend on repairs so any help would really be appreciated
  • Anonymous May 14, 2009
    COPIER TURNS OFF WHEN MAKING A COPY
Posted on Feb 16, 2011
Replace the exp lamp and try again after an error clear.
Posted on Jun 25, 2008
Clean photo sensor on interimage lamp unit above the drum unit , remove drum unit & toner unit and unscrew nail above drum the unit will go down . clean it and reassemple the machine it will work right
Posted on Jul 01, 2012
  • 3 Answers
Posted on Jan 20, 2012
CANON NP 6035 The error code E224
Bagaimana cara mengatasi error e224 ???
Salam Sukses By KBG.
Feb 27, 2011 | Canon NP 6035 Copier
Tip
ERROR codesCanon 6030
Canon 6030 E000 Fuser did not heat up E001 Fuser temperature too high E002 Fuser temperature not rising at correct pace E003 Fuser temperature drops E004 SSR shorted E210 Lens home problem E212 Lens home problem E220 Exposure lamp problem E224 Blank shutter home problem E240 DC controller or composite power supply problem E400 Data communication problem E401 Pickup motor problem E402 Belt motor problem E403 Feeder motor E404 Delivery motor E411 Document detect sensor E500 Communication problem with copier E510 Feeder motor E530 Home sensor E531 Staple swing sensor problem E540 Bin shift motor rotation problem E541 Bin motor E710 DC controller E711 Document feeder IC failure E716 Cassette feed IC failure E800 Auto power-off circuit problem E901 Cassette feed motor E902 Paper guide home sensor problem
on Jan 19, 2010 | Office Equipment & Supplies
I have machine canon 6030 np and there problem called : E224 please send how can I solve it
Basicly, a E224 is a scanning lamp error code. Here's a question for you??? Will the scanning lamp turn "ON" at all? If so, then the problem is with the scanner power cable. If the lamp will not turn "ON" you may have a blown lamp & or thermal fuse on the scanner unit. You can not clear the code until the problem is fixed. Good Luck
Feb 16, 2011 | Canon NP 6035 Copier
Sir i need your help
6330 canon e224 how can i solve this problem
Jan 30, 2010 | Canon NP 6035 Copier
Problem is E224
Hello sir; The error code you display E224 its means blanking shutter motor or senser.
E224
blank shutter not working may need to be replaced
Error message on canon np6025
LOL.... I just kept wiggling wires and connectors and all of the sudden it worked.... not real sure what I did .
Apr 09, 2009 | Canon Office Equipment & Supplies
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Canon np 6030
Is it looking for toner or is there still a jam in it. You may want to try to turn it off and unplug the sorter and turn it back on. If that dose not work turn off again and unplug the adf and turn it on again. If that dose not work if you have unplug the bottom 2 trays. If one of those is causing the problem look deeper in to one of those units. Also, will it showw or flash a error code on the display?
Mar 18, 2008 | Canon NP 6050 Copier
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
626 people viewed this question
k24674
