Question about Intertherm Heating & Cooling
Will run and cool until the thermostat turns it off and will not start back up. Inside fan continues to run. Compressor is completely dead.
  • 38 Answers
Dear jack289,
The thermostat is not working properly. When thermostat cutsoff the compressor Please turn the thermostat knob to higher setting if compressor starts working then please change the thermostat. The fan will run continuously since only the compressor is controlled by the themostat.
Regards,
ramesh22
Posted on Jun 25, 2008
The refrigerator is warm, not cooling.
If the refrigerator is warm, you need to answer some questions, then see if the compressor is running.
First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Good luck
Jun 25, 2010 | Bosch Evolution 500 B20CS50SNS
Refrigerator seems cool enough,freezer not so good ice cream turns to soup,frozen foods eventually softens. Amana BRD18V1C
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Mar 30, 2010 | Refrigerators
Refrigerator / freezer will not coo;
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, see “It's stopped completely.” Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor
Mar 29, 2010 | Refrigerators
Fridge not cooling
Mar 29, 2010 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
GE profile not cooling
Mar 28, 2010 | Refrigerators
My refrigerator is not cooling
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Mar 27, 2010 | Refrigerators
The compressor is running but no air cirulating inside its a side by side
You need to investigate in the folloeing order :-
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • The compressor
  • The Thermostat
  • The defrost timer
  • Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 07, 2009 | Amana Refrigerators
    GE refrigerator Model TFX20D Will not cool. Tested T-Stat, Defrost Timer and thermostat on coil. Still does not cool.
    • The compressor
    • The Thermostat
    • The defrost timer
    Jul 24, 2009 | Refrigerators
    Robertshaw 9420 thermostat engages inside fan in OFF position
    check with the company u brought it from and check if you have not put the correct conector to the right temals on the back of the switch.
    Jun 09, 2009 | Heating & Cooling
    Compressor starts and doesn't stop
    Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
    Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
    Heating & Cooling Logo
    124 people viewed this question
    Top Intertherm Heating & Cooling Experts
    Dennis Boxerman
    Dan Webster
    Dan Webster
    Bill Long
    Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
