Cannot turn on my Beko WMA520W AA class washing machine. Is their a lock or code?
  • Anonymous Mar 14, 2014
    where is the filter in my beko AA class 1200 rpm washing machine?
    President:
  • 1,462 Answers
Nothing special.
select program, shut door, press start button. there is a pause of few seconds before starting
Posted on Jun 25, 2008
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there:
Beko Automatic Washing Machine Installation Operating Instructions...
Sep 22, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Beko stuck on spin and drain,just fill again aa class 1000rpm
Try cleaning water pump filter it's probably blocked use the filter drain hose to empty .
Jul 05, 2014 | Washing Machines
Aa class beko washing machine wont spin or start a cycle
This Beko washing machine video will help you
We work very hard in our warehouse making free video guides for you all on cookers, ovens and washing machines Etc. Buy Paul Beer
Apr 02, 2014 | Beko Washing Machines
Aa class beko 1400 rpm in black...my washer has been fine until today...it did a wash and spun fine...then wouldnt unlock it just kept making a noise (like it was just about to start a cycle) for bout 4...
Try pressing start pause and cancel at the same time. This is the way to overcome a Beko door lock power problem. A bad sound suggests the belt has broken, and that can only be replaced by a technician
Mar 17, 2014 | Washing Machines
Beko aa class 1200 rpm washing machine will not drain **** on cycle
Possible that the program controller is not outputting to the drain .Check this link to repair the drain pump
Jun 28, 2012 | Washing Machines
I need a manual for a BEKO AA class 1000 RPM WMA 510W
help how do i make the machine do a quick wash
Sep 12, 2010 | Washing Machines
My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
May 14, 2010 | Washing Machines
MY BEKO WMA520W WASHER DOES NOT HEAT WATER UP
you need to check Heater element it should read about 32 ohms if ok on a multimeter, next the thermostat should be closed circuit, any loose wires....Hope this helps.
Apr 20, 2010 | Hotpoint Ariston WD440G Front Load...
I have a Beko AA class WMA 520W washing machine and it won't wash, when i put it on a wash cycle it will fill up wash for about 7 mins then drain, neither will it spin unless i actually turn the dial to...
Had the same problem this week. i bought the machine of a mate and was ready for kicking his head in, but thankfully before then i found that this method resets the washer, hope it works for you also
Turn power button off (not at wall)
Select 90 degree wash
Press Start / Cancel button down for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start /Cancel button again for 3 seconds.
Machine should be re-set ready for use
Oct 19, 2008 | Washing Machines
Beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
Jan 30, 2008 | Washing Machines
Washing Machines Logo
578 people viewed this question
Top Washing Machines Experts
