Question about Radio Shack Pro-2018 Scanner
The Display on a radio shack pro2004 does not light up but the scanner works well, which means that you have no idea what channel or Freg. it is on. Trusting you can Help is there new parts or S/Hand ??? Thanks Bob
    Brigadier General:
  • 6,966 Answers
To my understanding, this is a common problem with the PRO-2004 (2005 and 2006) model(s) concerning their electroluminescent panel going dim over time. In some cases, it is just a case of dead backlights.
Should it be the display, the catalog Number is 11137510, NP Part Number is XB1573 and the technical name/description is PCB ASSY,LCD.
You can try inquiring/ordering the part 1-800-843-7422 or visit your local RadioShack store.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 25, 2008
    Novelist:
  • 121 Answers
There could be a loose connection between the display and the circuit board. If you decide you feel comfortable taking it apart check and see if you can wiggle the display. If it wiggles it may just be a loose solder joint. Keep me posted.
If you found this solution helpful please rate it when you get a chance.
Thanks - Tech101
    Guru:
  • 1,894 Answers
Then mostly the tuning capacitor is dead i think
have u checked it>?
I have a radio shack pro 2096 that worked for years came home one day and no digital channels come thru anymore haven't touched a thing?!!
They have probably 'rebanded'- meaning that they moved the control channels. Go to radio reference dot com and see what the control channels are. IF they moved the 3 or 4 control channels and alternate control channels to the 700MHz range, then the PRO96 and PRO2096 probably cannot track it anymore and you will need a newer scanner from Uniden Bearcat or from Whistler. Let me know if there's anything else I can do to help.
Aug 21, 2013 | Radio Shack Pro-2096 Base Scanner
I have a Radio shack hand help police scanner, when I put the batteries in and turn it on, i just hear this low level static and some small clicking noise. The display finally came on for a few minutes but...
Take the scanner back to radio shack for an exchange. If you have had the radio too long then take the scanner back to radio shack and they will send it to their service center for repairs. Personnally I would upgrade to a digital scanner as things are getting ready to change nation wide. Most goverments will be upgrading to P25 digital to comply with the requirements of Homeland Security.
Jul 10, 2011 | Radio Shack Pro-95 Handheld Scanner
I need the freg to put in it how do I get them
http://www.cityfreq.com/
Go there, and choose your state, city, and organization you wish to monitor.
If this helps, rate me with 4 thumbs up! Thanks!
Feb 23, 2011 | Radio Shack Radio Communications
Clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
Mar 21, 2010 | Radio Shack Pro-95 Handheld Scanner
I can not get any sound out of my radio shack pro 97 scanner I turn the volume all the way up and hear a light uzzin sound I have it on the weather channel and no sounds my scanner saids all channels...
Nothing's wrong. All of your frequencies have been deleted (pre-programmed PLUS anything you entered yourself).
You'll need to re-enter all of the frequencies to get it working again.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
Need to reprogram hand held pro 96
Radio Shack can "CLone" your scanner with one in the store - try that first to see if it will work and let me know.
Aug 19, 2009 | Radio Shack Pro-96 Scanner
I have a Radio Shack Pro-96 Digital Handheld scanner with at least three channels locked out. My fault but would like to get them to work again as I have a $500 scanner and it is locked out on these...
Are you talking about banks? (0-9) If so, choose one sole bank (i.e. 7) and press MAN, then PGM, then TRUNK. Once here, Press the FUNC key on the left hand side and I believe you press "1" on the keypad afterwards. This will unlock the specified bank. If it is no "1", try the other numbers. Hope this helps...
Jun 05, 2009 | Radio Shack Pro-96 Scanner
Pro-96 antennas
It will only work with a crome antenna.
Jun 05, 2008 | Radio Shack Pro-96 Scanner
"ALL CHANNELS LOCKED OUT' RADIO SHACK COULDN'T HELP.
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box. To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Feb 28, 2008 | Radio Shack Pro-97 Handheld Scanner
Police sanner freg
Radio Shack should be able
to supply frequency manuals
Nov 14, 2007 | Office Equipment & Supplies
Radio Shack Pro-2018 Scanner Logo
98 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
