Question about Dell Latitude D600 Notebook
Installing internal board dell d600 nic hardaware
Need to install Wireless internal nic adapter for dell d600
    Genius:
  • 2,028 Answers
The wireless card bay is located under a panel on the bottom of the machine. It will have two leads (wires) the plug onto it. There will be only one place that the card fits and you will know it when you see the two wires. After installing the card, then you will need the drivers in order for it to work properly, you can find the drivers at driverguide.com using the make and model of the card. Also, the two leads will only work properly if connected correctly. The card will work if connected wrong but the reception will be lousy. If you find that you're not getting a good signal after everything is installed and working, try switching the wires.
Posted on Jun 25, 2008
I had a working Dell computer - accessing the internet through a wireless router - computer became unbearably slow - re-installed Windows XP 2002 SP1 everything's fine except the network adapter that was...
You don't say what make/model of network adapter (NIC), whether it's wired or wireless, or if it was operating under the same service pack level before, so I have to make a lot of assumptions.
Is Windows really not recognizing it (ie: does it have an exclamation mark next to the NIC in device manager?) or is it being recognized by Windows but just cannot connect to the wireless router? If the latter, check your wireless configuration (SSID, WPA key, etc). Since you have WinXP SP1, it could be that there is not a driver for that particular NIC. Later service packs include updated drivers as well as bug and security fixes. Recommend you identify the NIC and if you have the driver disk for it, go into Windows device manager to select a reinstall from that disk. If you don't have it, use another computer to download its driver and after installing it and getting Internet access, you should also download and install the latest SP, which would be SP3.
Feb 18, 2011 | Dell Ethernet Card Network Adapter
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
Installing NIC card to dell optiplex gx100
NICs usually come in PCI interfaces. motherboards have usually four PCI slots to hold many devices such as NIC. just slide the card and fit it into the PCI slot. It could take any of the slots where it fits. the OS will detect it and loads the necessary drivers.
Aug 28, 2009 | Dell Ethernet Card Network Adapter
Display problem - Dell D600
Try re-installing the ATI Redeon graphics driver (video driver). If problem persist, I suspected its your video card is having a problem. I believe it is built in on your machine. So you need to replace a system board.
If machine is under warranty, no need to pay for the repairs.
May 16, 2009 | Dell Lattitude D600 W/XP Pr Notebook
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Install internal nic card
please specify your problem,are you referring to the nic driver? or the hardware? it its the hardware,you cant because it builtin with the motherboard,you might try to purchase usb to nic adapter
Jun 24, 2008 | Dell Latitude D600 Notebook
Latitude D600 Network problem
unplug roughter then back in after 1 min and modem ok then rebooot give it a min
Jan 20, 2008 | Dell Latitude D600 Notebook
NIC
What error code was given when you tried to install the Broadcom 570x. What operating system? (WinXp, Win2000, Vista)? I would go to Dell's website and download the drivers shown there for the Latitude D600.
Mike
Dec 15, 2007 | Dell Latitude D600 Notebook
Network adapter or nic
Dear browns92,
NIC is allready inbuilt in laptop
check port carefully where RJ-45 connector is connected
Dec 14, 2007 | Dell 430-0008 Network Adapter
Dell Latitude D600 Notebook Logo
864 people viewed this question
Alun Cox
