Question about LG Televison & Video
LG PROJECTION TV. I`M NOT ABLE TO ADJUST CONVERGENCE ANNYMORE. THE BLUE PROJECTEUR IS COMPLETELY HOT OF FOCUS.IMPOSSIBLE TO MOVE ON THE RIGHT OR LEFT SIDE BLUE PROJECTEUR.
  • 4,234 Answers
There is a problem with the convergence circuit that requires service. If you can solder, you can repair this yourself. First try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. There may also be some small Pico fuses located close by that should be checked if replacing the ICs as well. These ICs are large black ICs attached to a heat sink and should be marked STKxxx.
Please keep us updated on your progress.
Thanks,
Dan
Posted on Jun 25, 2008
"touch focus error" appears when the test is completed. There is a double effect showing on the pictures and the words. What can be done to fix this?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Toshiba 65HDX82 65" Rear Projection...
The tv scren is wavy on the left side but the screen is still visible on the right should I use the magic focus button
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 11, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Green convergence will not adjust
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 23, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Blue and red wavey lines and distorted picture
May 20, 2010 | Toshiba 53H71 53 in. Rear Projection...
Is my lg 52sz8r able to go 3d as in the menu it
  • Screen looks 3D
Apr 05, 2010 | LG RU-52SZ51D 52" Rear Projection...
Conversion-----the red lines are distorted so badly they won't move at all. I've managed to line the other lines up. The top left quadrant has drooped so badly that they will not adjust back. The bottom...
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
Feb 11, 2010 | JVC AV-56WP74 56" Rear Projection...
Red gun convergence problem
  • Screen looks 3D
May 16, 2009 | Toshiba 65HX81 65" Rear Projection...
Apex GB43HD10 Convergence
  • Screen looks 3D
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Shadows on left side of screen,right side has no shadows
  • Screen looks 3D
Nov 28, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Convergence problem with TV Pojection Sony KDP65WS550
  • Screen looks 3D
Oct 08, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
Computer Repairing
Computer Repairing
