Question about Sony PlayStation 2 Slimline Console
Disc won't eject
Disc stuck in player, when powered on, green light appears briefly then turns red and unit shuts back down
Called Sony, they had me hold my hand at rt rear of cabinet -- fan was not blowing ... apparently blinking red is indication of overheat ... Sony will repair free and replace the blue ray disc that was "eaten"..... they said problem was not consumer repairable and that if I had opened the cabinet ( I nearly did) I would have voided the warranty
Posted on Jun 27, 2008
  • 21 Answers
Press the disc eject button
My PS3 80Gb shows the red standby light as normal. When I push the power button, I hear one beep, as the light go from red, to green, to off, and then finally back to red again. If I push the eject button...
Does the lights blink red? If so, You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED*
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
You will have to have the system repaired so that you can eject the disc the normal way. If the technician cannot repair your system, simply ask him to remove your disc.
Feb 03, 2011 | Sony PlayStation® 3 (80GB) Console
My playstation 3 when turned on power light turns green then yellow and immediately turns red...unfortunately i have a game stuck inside console..please help !!!
IT CAN BE FIXED*
FOR THE DISC THAT'S STUCK INSIDE?
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
I was watching a film then my ps3 suddenly shut of with the red light constantly flashing, so i went to turn it back on and and then the yellow light came on and it shut back down with the red light...
IT CAN BE FIXED
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
When you switch it on im getting the red light then green for a second then back to red
Does the lights blink red? If so, you have the infamous YLOD, aka. Yellow Light of
repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself. You could make things much worse and render the unit totally unresponsive.
Jan 19, 2011 | Sony Playstation 3 (PS3) Console
Went off in the middle of a game and now the system light will turn green and then blink red and the game will not come back on.
Jan 17, 2011 | Sony Playstation 3 (PS3) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
While playing a game console turned off and game disc is stucked inside, turn power on and light turns green for couple seconds then flashes red and turns back off, no chance to eject game disc.
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked.
The blinking red light is infact a general hardware failure message. In this particular case, his hardware failure is with the blu-ray drive, that's why the system does not shut down until the drive is accessed. if the system is overheating, it will tell you so in the top right hand corner. It will say the system has overheated and is shutting down to avoid further damage.
Provide a proper vent for the system...
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
Wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Jul 28, 2009 | Nintendo Wii Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 Slimline Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
