Question about Kyocera Office Equipment & Supplies
FS 2000 using compatible toner, Low toner light will not go out. Can I reset the printer?
  • jbarso Jun 25, 2008
    Kyocera FS 2000, using a compatible toner cartridge. when I install the low toner light will not go out. is thia a chip issue or can I reset the printer menu?
  • 3,037 Answers
Try unplugging it for five minutes to reset the printer, if that doesn't work, then uninstall and reinstall the drivers.
Also make sure that you took the tape off of the cartridge. Also, is the cartridge the exact same one that you used to have, if not and it is generic, that could be causing your problem. Also, are you able to print with it even if it says low? Please let me know and try what I suggested and I would be glad to further help you with this
Posted on Jun 25, 2008
    Genius:
  • 1,036 Answers
Yes this my be due to a chipped cartridge (as in microchipped)
If you have refilled it once successfully, it may have reached it's expiry date.
The only way around this is to replace it with a similar cartridge, and cycle them in a series of 4. If you can get acces to another machine to swap them over, this will also work.
This is another money-making scheme from the manufacturers to get you to buy more products.
(Please remember to rate solutions so that others may benefit from good advice. Thank you.)
    Brigadier General:
  • 3,614 Answers
Any error message have happen to your printer..?
  • micromaster
    micromaster Jun 25, 2008
    try to remove and unplug the machine for a while
  • micromaster
    *remove the toner
    Guru:
  • 1,894 Answers
Reset it and check if it disappears
  • dewan nafees ahmed Jun 25, 2008
    disconnect the unit from power fully and leave it for few hours
    and then again connect it
    this must help u to get to work again
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
How do I reset the toner level?
you can't there is a crum chip on the toner cartridge that would need to be replaced. refilling is a bad idea by the way. it ends up costing you alot more in repairs on down the line
Nov 16, 2015 | Kyocera FS-1030D Laser Printer
I've refilled Kyocera FS- 1135 mfp then not genuine toner had detected.. but the toner i used is kyocera compatible toner and its working to other kyocera machines.. Is it because of the IC chips or what?...
Kyocera compatible does not mean Kyocera genuine. Not using genuine toner can invalidate your warranty. If that doesn't bother you then the printer detecting a non-genuine cartridge is not an issue.
Sep 02, 2013 | Kyocera FS Office Equipment & Supplies
Kyocera FS-C5030N Led Printer My printer ran out of the blue (cyan) toner so I replaced the cartage carefully following are the cleaning steps like I've done successfully before with the other colors....
You need to reset the toner counter. This is done through the Menu button and selecting Life Counters. The instructions on how to do this are found in the Advanced Operators Guide on page 2-75. The link below will take you to the manufacture's website where you can download it.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=14192&rid=14764
Resetting the Toner Counter
The toner containers must be replaced when the printer displays the Low toner or Replace toner message which will be given depending on the color of toner. The Low toner message will be shown as a pre-warning that the toner is running out and the printer will soon stop, at that time showing Replace toner. If you replace the toner container before Replace toner is displayed, you must manually reset the toner counter as explained below. Note that if you reset the toner counter before the toner container is replaced, the subsequent toner warnings will not be indicated correctly.
I hope this is helpful,
Shawn
Mar 09, 2011 | Kyocera FS-C5030N Led Printer
Kyocera laser printer toner refill
refill...uh oh probably wouldnt try it..there's is like only 1 company that does kyocera refill toners.....call KATUN... you can try to find that on the internet..you most likely willl have to buy actuall kyocera toner..
Jan 24, 2010 | Kyocera FS-C5015N Laser Printer
I have a Kyocera FS-2000 printer with this problem: ''Service Call 7410:0033161'' Can you help me?
This code is because the printer believes that the drum is not installed.This usually happens when the waste toner container is changed,Open tje waste toner cartridge door and push into the printer all the components.You will find that the drum unit will push into the machine.Then close the door and turn the machine off at the wall.When you power back up the error code should have reset.
Oct 09, 2009 | Kyocera FS-2000D Laser Printer
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
I have a ml-2571n and after my toner got low on a cartridge, I replaced with a new one and it still flashes the toner low light. Didn't know if there is a way to clear or reset or if this normal. on this...
It's not a "new cartridge" is it? it's remanufactured or compatible?
There is a fuse on the front of the cartridge that is either missing, or defective. this is what resets the toner counter
Apr 08, 2009 | Samsung ML-2571N Laser Printer
Kyocera Ecosys FS 920
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Kyocera Mita FS-1030D Laser Bottom 2 lights blinking.
I think the two lights flashing together indicates waste toner box missing or full but as this printer doesn't have a waste bottle I assume it means the processing unit (ie the drum bit) needs replacing.
Apr 22, 2008 | Kyocera Mita FS-1030D Laser Printer
114 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
