Question about Quad 11L Main / Stereo Speaker
Need to replace 11L tweeter
I've blown the tweeter in my 11L. I have a new 11L tweeter but need to open up the 11L somehow. Can anyone post a picture, or just tell me how to open up the 11L?
I've taken off the grill, and used an allen key to remove the 4 bolts around the tweeter - but the tweeter does not budge at all.
Any ideas?
  • akil_nasser Jun 25, 2008
    Great! As I thought.
    So what tool would you use to wedge out the woofer without damaging the lacquer coating and the rubber around the drivers?
    Is a knife too tough?
    Should I deliver it to a service centre? Only unauthorized ones are available where I am (in Dubai). The cost of labour is approx $80.
    Akil
The best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Posted on Feb 07, 2010
  • 4,234 Answers
Your speaker is designed as a sealed system. This means that along with the screws to hold down the tweeter, there is a putty seal. This acts more like glue over time. You will need to carefully pry the tweet out of the hole. You may find it easier to pry off the woofer first, then reach inside the cabinet to push out the tweeter.
Keep us posted on your progress.
Dan
Posted on Jun 25, 2008
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
I loaned my fender passport 300 to some friends. They said they ended up using it as a mixer on a larger system. Now one speaker works normally on one output. when i switch that same speaker and wire to...
It would appear they've blown one channel on the Amplifier and one Tweeter on your Speaker. It's more than likely that the Tweeter has blown first and overloaded the Amplifier.
The Tweeter shouldn't be a problem to replace (eBay more than likely) and you'll probably be better getting a new pair and replacing them both.
The Amplifier could be a different issue depending what Country you're in and your Technical ability?.
If you need any further assistance once you've opened the unit then just ask.
Please leave feedback
Cheers
Andy
May 08, 2011 | Fender Passport P-10 Professional...
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
Mission 753 spares / tweeters hi can you help me please ? my tweeters from my mission 753 floorstanding speakers have blown.. been in contact with mission, and have been told that they no longer have...
Hi Ricky...saw your post re the 753 Mission tweeters. Your post goes back some months ago but I wondered if you got fixed up with replacement ones or a workaround ??
Regards
Wayne
urban494@hotmail.com
Jan 29, 2010 | Audio Players & Recorders
Front speakers
either the wires in the boot where door folds open has broken wires in it or the most likely case you have 2 blown wolfers and 1 blown tweeter. common for cars with the monsoon stereo system, they made the radio better than the speakers.
Mar 09, 2009 | 2001 Volkswagen Beetle
Re: Quad 11L tweeter doesn't work
If you sure it is working and new then ,maybe connection error,try to review the hooked up connection maybe there might be interchange;
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 25, 2008 | Quad 11L Main / Stereo Speaker
Re: Quad 11L tweeter replacement
Given the relatively small cost of the repair, I'd have the servicer do it. That way if anything happens, he/she is respionsible for it. When I repair this type of speaker, I usually use an old chisel. It is sharp enough to get under the edge and strong enough to pry up the speaker. Just be careful not to nick the cabinet.
Dan
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Tweeter not working on 15" EON G2
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Jun 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
Quad 11L Main / Stereo Speaker Logo
799 people viewed this question
Top Quad Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Quad Audio Player and Recorder Expert? Answer questions, earn points and help others
