Question about Xerox DocuColor 3535 Copier
Xerox 3535 Can anyone help... we have a xerox 3535 which keeps saying a fault has occurred and we cannot clear it without calling out xerox. It does not give the fault number
  • Anonymous Jul 16, 2008
    Copier has stopped for a consumables replacement. I replaced the IBT and H roll assmbly. The parts have been replaced but the copier has not reset. can I do the resetting?
  • sly4you Sep 18, 2008
    I have replaced Second Bias Transfer Roll and TRansfert Belt Cleaner,
    but Xerox are already locked with replace parts alert in "consumable" section.
    How I can reset counter?
Email
Posted on Jul 15, 2008
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
How do I clear the fault codes on a xerox 3535 printer?
http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Feb 12, 2015 | Xerox DocuColor 3535 Copier
Problem with a Xerox Docucolor 3535 Copier
Reset the tranfer unit counter,and change the transfer unit chip fuse(located in transfer unit contact house)
Apr 12, 2012 | Xerox DocuColor 3535 Copier
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
Xerox Docucolor 3535 fault code 006-372
That is a problem with the laser or ROS polygon mirror motor.
It most likley has failed.
Google a business called The Parts Drop, call and ask for Britt.
They can help you parts wise. Its not real difficult to replace.
Oct 24, 2010 | Xerox DocuColor 3535 Copier
Xerox Phaser 8500 Fault 34,001.43:3113
34,001.43: An error occurred while attempting read/write access to the
Printhead calibration partition in NVRAM. The Printhead cable may be
unplugged. If you have checked all the cables and nothing is ripped then you might have to change the print head.
Part# 046K00530 You can call this company on my directory they even give you the instructions how to do it yourself. They can give you free technical support. Hope this helps.
Nov 19, 2009 | Xerox Phaser 8500/DN Printer
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
XEROX 3535 FAULT CODE 010-350
foult code 010-348 pleas solve this problem
Apr 04, 2009 | Xerox DocuColor 3535 Copier
Xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
Mar 16, 2009 | Xerox DocuColor 3535 Copier
406 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
