HP Pavilion dv2000t Notebook Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP dv2000 shuts down and does not turn back on. The power cord is connected but the charging light is not on.
JDTec
Level 3:
  • HP Master 4,338 Answers
  • Posted on Nov 30, 2010
JDTec
HP Master
Level 3:
Answers
4338
Questions
0
Helped
2127830
Points
14653
Your DC connector on the system board is loose:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If it is under warranty, HP will repair it. If not , read this:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Replaced battery 2 months agoon HP zd7010 when I kept getting low battery/cannot charge/must shut down. If I removed battery and was connected to power cord, the laptop would boot/work. Now getting same...
know one here can answer any of that.
if the power pack is good, 19vdc in to the mobo then its GOOD>
if not not.
if the battery is bad, it can cause a dead system. shorted batteries do that, so leave it out. and run on the power pack
why not do that?
lets say battery out it still fails..
so the power pack is bad or the jack on PC is bad.
ive seen cloned battery packs from china fail in 1week
many. if you watch the news ,some catch fire, and lots of recalles.
even hp.com has recalls.... for this... as do all makers....
Batteries by there nature are problematic, for 100 years now...
whats the point there? use HP packs?
why not have 2 batteries , so when one fails the other yells
see I WORK>?
1helpful
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
1helpful
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
HP dv2000 fails when power supply connected
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
I have a hp dv2000 thats not turning on the power light comes on
Disconnect the ac adaptor and battery and then press and hold down the power button for 30 sec, and the relese it and connect the ac adaptor and battery and try 2 turn on the NB
HP Laptop Seem to Charge but Wont Turn On
When you plugged the power cord back in did the green light on the power cord battery light up. How long have you had the cord. Make sure the power cord is working properly.
Doesnt stay on
sounds to me like power cord failure.  it is running off battery power and with no power cord it cant recharge and shuts down to save data
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
