Question about Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint ffa70 The compressor is working but neither the fridge or freezer is getting cold.
  • kriz331 Jun 26, 2008
    Many thanks for your help
  • reg1966 Jul 05, 2008
    Hotpoint FFA70 Fridge freezer,Freezer high temp light is on constantly,have already de-frosted and re-started,the light has stayed on and the freezer is not freezing.
  • 958 Answers
If you are sure that the compressor is running and there is no cooling, then you could have a leak in the system and there nothing you can do about it. you should ask a professional to repair the leak and recharge the system .
i ask if you are sure because you might think of the vibration of the condenser fan motor if there is as the vibration of the compressor. they are two different motor running at the same time.
Posted on Jun 25, 2008
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
My fridge freezer hotpoint future is not working i can here freezer but its not getting cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Top part of my fridge is not cold but freezer is working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 09, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge not working (light on - not cold) and freezer working fine.
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 18, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge and freezer not getting cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Oct 03, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezer hotpoint ffa70 - The freezer overheat light came on and the freezer stopped working, followed by the fridge not working about 4 days later. Now it just doesnt work at all!
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 06, 2010 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
Hotpoint FFA70 Freezer High Temp
sum fans only kick on if cold enough
if the whole evap is frosted up u have a defrost problem
if frost is only partial u need to throw it out cause it either has a bad compressor or freon leak
check your fan by compressor and make sure coil isnt filthy too
Jul 08, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
135 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
