Question about Briel Chamonix ES-35 Espresso Machine
Coffee basket I think I need a new basket or at least the plastic bit and screw that holds it in.  Where can I get I get one in the UK please?
Contact Electra-craft.com..they are in New Jersey
Posted on Feb 21, 2009
Need a new coffee basket it is plastic the number is 7036.
You can order a replacement basket online from either of the the following sites:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=948&secid=87&linkon=subcategory&linkid=125
or
http://www.abtecparts.com/westbend_urn_baskets.htm
The P122-45 should fit your coffee urn. West Bend has 2 different 36 cup coffee urns, both use this same basket.
Thank you for using FixYa!
Sep 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
My gr10w bunn coffee maker leaks while using.I think it overflows the filter then leaks down. I use Bunn filters. please help!
If it is leaking out past the filter basket, it can be fron two things- either the basket edges are worn out, and is allowing water to leak past it, or the hole is being partially blocked by scale or caked coffee. in the first case, try replacing the filter basket. In the second case, you can either clean out thr hole or try running a drill bit through it to clear the hole.
Mar 13, 2010 | Coffee Makers & Espresso Machines
Black & Decker SpaceMaker leaks badly.
It has nothing to do with the spring or its tension. I have had 3 of these coffee makers now. Each on has started leaking water from the reservoir after some amount of time. If you carefully look at where the rubber washer/spring thing is, right above the hole where it goes in, you will see a small "crack" in the plastic that develops after repeated use of this coffee maker. That's where the water is coming from. Each one of the reservoirs I have had has developed this crack in the plastic right there. It is a design flaw. I will never buy one of these again.
Feb 26, 2009 | Black & Decker SpaceMaker ODC325 Coffee...
No water coming out of left coffee nozzle
You can soak in purocaff up to the plastic, or you can remove the basket using a small flat screwdriver to pop it out, and clean the spouts.
Jan 08, 2009 | Rancilio Silvia Espresso Machine
How do I put the spring back in that holds the door shut.
The replacement basket costs around $6.00 - don't fiddle with it, just a buy a replacement part from Cuisinart's website.
Nov 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Spares
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc 41 Woodbine Street Bergenfield, NJ 07621 201 439 1700
Aug 27, 2008 | Briel Domus Due Espresso Machine & Coffee...
Filter pops out in middle of cylcle
I periodically take a wet Q-Tip and clean around and inside the "slides" for the brewing basket door, so that it slides in and out easily. (I was amazed what the Q-Tips look like after you do this.)
I think the problem lies in the fact the basket does not go fully back and engage the latch due to the gunk that builds up on the slide. You think you fully closed the door when you feel the resistance of the gunk, but you are only marginally latched - the vibration of the motor pops the door free and VIOLA! coffee-ala'-counter!
I think the gunk comes from very fine ground coffee dust, mixed with water that condenses from the steam that envelops the unit during brewing.
I also clean every surface in the brewing basket area with a wet paper towel,
Mar 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
Cuisinart Grind & Brew Thermal Coffeemaker DGB-600
I suffered with a stuck grider unti for a long time and just solved the problem..... Remove the filter basket and through the front door look up twords the back left. You can see where the grinder unit sits. There is a slot area where you can stick a screw driver under the grinder unit and pry it up. Do this in a jiggling motion and make sure you are well under the grinding unit, doing so on the edge of the grinder unit underneath will not give you enough suface to work with, in fact you will just bend or crack the edge. Looking in from low on the front (kneeling on floor with unit on counter, worked for me) will let you locate where the screw driver or smal pry tool needs to go. Mine was stuck for a very long time and No amount of pulling or prying from the top would work, I made it pop out in a matter of seconds using this technique from the bottom! Good luck, I'm going to finish my cup of coffee now! :-) Steve
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Briel Chamonix ES-35 Espresso Machine Logo
85 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
