Question about Samsung (SP0411N) 40 GB Hard Drive
Bad disk My hard disk is having bad sectors. I don't know how to remove it. Operating system has crashed & I'm unable to install operating system on it.
  • 36 Answers
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Posted on Jun 28, 2008
How do I remove the "Non-system disk or disk error" message on HP Compaq nc6400?
That error means either your hard has failed, has bad sectors or the operating system has corruption. Worst case you will need to replace the hard drive and re-install everything. Best case you will need to re-install everything again. You could try and run a program called Sea Tools to attempt and repair bad sectors on the drive.
Mar 19, 2014 | Computers & Internet
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Need to reboot i can't even get to the start screen, it keeps telling me to put in a disc.. i don't have a disk drive
This error means that your hard drive isn't functioning correctly. The computer is attempting to load the operating system off your hard drive but the computer can't find the operating system. There are several causes for this problem:
1. The hard drive has crashed.
2. The boot sector and/or operating system has become corrupted.
3. The hard drive has become disconnected from the laptop; this is unlikely but possible.
To determine what has happened follow these instructions:
1. Turn off netbook and remove all usb devices.
2. Turn on netbook and press whatever key enters the boot menu; often it is ESC or F10 - look on the first screen you see when you turn on the computer.
3. Look at the possible devices listed that you can choose from. If the hard drive isn't listed, then your netbook isn't detecting the hard drive likely because it has crashed. At this point you're going to have to take the netbook to a repair shop.
4. If your hard drive is listed, then it's possible that the hard drive is fine but that the boot sector has become corrupted. If you have access to a USB CD-Drive and a Windows installation disk or have a way to create a bootable USB flash drive, then there are some solutions that can be attempted. If you don't have access to these things, then you will have to take the netbook to a repair shop.
If you do have access to a Windows installation disk or can create a bootable USB flash drive, then post back to this solution and I can help you further.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 12, 2011 | Coby NBPC1023XPBLK Netbook PC
My hard drive got bad sectors
if ur hardrive has bad sectors you mite have to replace it u can usally get a cheap hardrive off of ebay.
Apr 10, 2011 | Computers & Internet
Hi !
For some reason, some hard disk will be damage due to bad sector and you cannot do anything about it not reinstall any operating system.
If the Hard Disk Drive failed to install the operating system, the hard drive is damaged and cannot be reformat. The only solution is to replace new Hard disk drive to install the operating system.
Jan 07, 2011 | Computers & Internet
My daughters tecra m1 refuses to format and gives disk is not accesible.i can fenagle it to get past that, but it just stalls out.ive ran chkdsk,etc.all checks out.puzzled.loaded operating...
Either the HDD controller is bad or the HDDs you used have bad sectors.HDD regenerator software alot of times will correct the bad sectors and then the OS will install correctly and function smoothly.
May 06, 2010 | Toshiba Tecra M1 PC Laptops
Blue screen on dell svc tag:GSKTL1S.Ox000000ED,0x8734D9EO,0xC0000006 how to fix this error?
Fine..You have reached the Blue Screen of Death (BSoD)..common in Windows Operating Systems. Generally this must be a hardware problem. If parts liek RAM or bad sectors in Harddisk, such BSoD comes, indicating the crash of the OS. Try repairing XP using the cd. If not, go for a format so that the bad sectors in the Hard disk is repaired.
Thank you!
May 30, 2009 | Microsoft Windows XP Professional for PC
Display hardware or drive broken
format your laptops's harddrive and install the operating system. When computer crashes very often, it is better to format it and install the operating system. Don't opt for quick format. This will help you to detect bad sectors. If there is bad sector, you have to replace the hard disk.
Jan 30, 2009 | Acer Aspire 5920-6727 Notebook
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Your hard drive is divided into bits called sectors. When these sectors start to go bad, that means that the computer cannot read or write any data on those sectors. You cannot remove bad sectors and once you start seeing bad sectors it is a sign that your hard drive is about to crash permanently so you need to replace your hard drive and make sure you back up all ofyour important data immediately.
Jul 06, 2008 | Computers & Internet
Samsung (SP0411N) 40 GB Hard Drive Logo
395 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
