Question about Goodman CLQ36AR49 Air Conditioner
Goodman A/c not working. cannot find manual. landlord away
Hi, our goodman split system reverse cycle a/c is not working. When I turn it on, it just blows fan air, and when I try to press mode on the remote, it beeps but the mode on the a/c doesn't change. There is a blinking light next to the "drop" symbol.
I'm not sure if it is the correct model
    Novelist:
    Champion:
  • 230 Answers
Try replacing the batteries first. The blinking may be the battery indicator.
The fact that it blows air when you turn the thermostat to cool tells me that the thermostat is probably working. The problem is most likely outside at the condensing unit. There are lots of potential problems that could be found out there. Sounds like you will need a technician.
Posted on Jun 25, 2008
Goodman air condenser is humming but the fan does not come on
The most likely cause is the fan motor has failed. If it turns free then see if the capacitor is bad. Turn off the power remove the capacitor. Your local supply houses can test it for you.
Feb 15, 2013 | Goodman Manufacturing Goodman GSC130181...
I am looking for how many tons of cooling my goodman condensor provides
  • Here's the data you requested:
  • Goodman CKL42AR42 Split System Air Conditioner
  • Type: Split System
  • Cooling Capacity: 40000 BTU/hr (3.3 tons)
  • Energy Efficiency Rating: 9 EER
Mar 19, 2010 | Goodman CKL42AR42 Air Conditioner
In a goodman system . in what mode is the reversing valve energized
When the valve is energized it will be in the cooling mode...if you remove power from the valve it will go to heating mode.
The only two systems that works the other way are the Rudd and Rheem systems.
Heatman101
Feb 11, 2010 | Goodman Heating & Cooling
We live in SC, have a Goodman 4 ton split system w
First of all is this unit a heat pump i'm not up on goodman model #'s if it is a heat pump reversing valves do go not a real common problem 1000.00 is excessive i would be inclined to get a 2nd opinion. plastic over the sand could create a condensation mold problem. Good luck. Tom
Jun 23, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Apr 28, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
291 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
