Question about Epson LX-300+ II Matrix Printer
One pin not striking
Its a nine pin printer. 4th or 5th pin is not striking when printing. What to do.
    Brigadier General:
  • 6,966 Answers
On most Epson 9pin printers, common causes for a missing dot are:
  • print head, the coil has burned;
  • stuck pin, the print head is held by a single screw and connected by a single flat flex cable. It can be removed and cleaned with electrical contact cleaner and/or WD40;
  • transistor on the logic/controller board. There are two PCBs inside these printers; one for the PSU, the other (bigger) has several medium sized transistor. One row would have 9 of these, one or more would be open (not shorted, if it were shorted, the pin would be leaving a continuous vertical mark on the paper).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 27, 2008
89 Yamaha Venture Royal 1300 shifting problems. stays in 3rd gear and wont shift up to 4th or 5th
Hi, Rick and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
No 4th or 5th gear on 1983 yamaha venture
KTM stuck in gear or wont shift repair
http://www.yamahaventure.nl/pdf/servicemanualxvz1300.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/ownersmanualxvz1300.pdf
Oct 01, 2017 | Yamaha Motorcycles
I AM HAVING PROBLEMS PRINTING, THE QUALITY IS VERY FAINT, i HAVE REPLACED THE INK AND CLEANED THE HEADS BUT STILL NO JOY,
1st See if it prints normal from a maintenance function such as clean printer cartridges. 2nd see if you need to update drivers and clean the cartridge electrical connections with a pencil eraser. 3rd Make sure all your print preferences are correct, did you put it in draft mode to save ink? 4th check trouble shooting in your users manual or contact Kodak. 5th Printers are cheap you can get an all-in-one wireless canon from Walmart for about $100. 6th enjoy your new printer.
Aug 15, 2015 | Kodak ESP 5250 All-in-One Printer
2010 crf450r jumping outta gear from 5th to 4th all other gears work fine
Terrence >>>> 1. Do not go through the gears while idling on a stand!!!
The rear tire is not moving at the speed that is normal for 4th or 5th gear..AND if you do get the tire moving that fast.. it is BEYOND DANGEROUS!!
This sounds like the 4th and 5th gears may need replacing.. or the shift drum detent for 5th gear has somehow become ineffective.. If you continue to ride this bike , you may cause more trouble and damage to the transmission.
Take this to a qualified professional!!
Jun 24, 2017 | Honda Garden
Recyled ink isn't being recognized
Have you reset the Chip on the cartridges. What model you use--- a nine Pin or old seven Pin model. Nine Pin are difficult to reset, seven Pin are easy with a hardware Resetter. If Chip show empty cartridge, you can fill them two days, it will show empty-- reset the Chip!
Apr 17, 2009 | Epson Stylus Photo R260 InkJet Printer
Puzzle 100 in professor layton
This took me ages. Hope it not too hard to follow.
1st square is a small one made up of the top left four pins of the 1st and 2nd row,and is the only straight square on the board.
2nd square is made from 3rd pin top row connected to 5th pin 2nd row, then make a sq from here.
3rd square is made by connecting 4th pin top row to 3rd pin down on far right row, then make the largest sq from here.
4th square is made by connecting 5th pin top row to top pin in the far right row then make the sq from here.
5th square is made by connecting 3rd pin 2nd row to 2nd pin down far right row, then make the rest of the square from here.
6th square is made by connecting 3rd pin across on 3rd row to 4th pin across on 4th row, then make the rest of the square from here. Finally 7th square is made by connecting 1st pin 4th row to 1st pin 5th row, and make the rest of the square from here.
When I describe pins, I am talking about actual pins, not counting gaps where pin could be.
Hope this helps.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Epson LX-300+ II Matrix Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
