Question about HP LaserJet 5si Printer
Power on , but on screen said need services - HP LaserJet 5si Printer
    Genius:
  • 1,089 Answers
What's the full message displayed?
Posted on Nov 30, 2010
Solution off error code 000002 off IR 3245 Canon ?
Hi. That error means there was a temperature error . You need to enter into service mode to clear that error.
with the copier powered on press the next secuence
press adittional function once
press 2 and 8 at the same time once
press adittional function once again.
service mode should appear in the screen. If it doesn't. Repeat the procedure.
with service mode in the screen :
select COPIER.
Select FUNCTION
Select CLEAR
in the list below select ERR and press ok in the lower corner of the screen .
turn off from the main switch of the machine for about 10 seconds.
power on the machine and make some copies .
if problem persist that mean that fixing heater is defective and need to be replaced
Feb 26, 2018 | Canon Office Equipment & Supplies
Power on. No picture on any channel. Flickering Light Grey screen with feint horizontal/diagonal stripes.Sound good all channels. Occasional shrinking/fading screen.
plz check the cable in another television, if the problem is not with the cable line then your television needs servicing
Jul 05, 2008 | Televison & Video
Change power supply,but screen turn on for 1 second then off
You have to enter its service menu option, and make all suggested adjustmens there, after power board replacement. Download its service manual. Not user manual. It will have all service adjustments.
May 23, 2012 | ViewSonic N3252w 32 in. LCD Television
Bought it in 2008, now it comes on for 90 seconds then goes out. Probably a bad inverter or power supply board. Are parts available for this monitor?
Is it the screen that goes blank or the power of the monitor? is the power led button on?
If the power led button is on, and it is the screen that goes off, this indicates that the picture board of your monitor is malfunctioning and will need to be replaced.
But if it is that everything goes off, it means the inverter is bad and will need to be replaced.
For the parts, yes, Being HP is even advantage, because virtually,most service centers do have the parts
Just walk to any hp service or any service center within your vicinity to get them.
Take care
Apr 25, 2010 | HP w1907 LCD Monitor
Power turns on but said call for service.
take ther lint screen out clean under hot water and a good brush
clean out vent system from the dryer to the wall
make shure the flappers outside are free and clear
if still not work u will need a qualified repair person to go farther
(solv ya prob)
Oct 18, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Jun 11, 2008 | Samsung Televison & Video
Flat screen doesn't want to come on
The power supply might be defective on your TV and will need to be replace.
I service these power supplies, since there are not many replacement service parts.
Let me know if you need more assistance.
May 02, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Screen problem
Hi there!
This is where service technicians make finer adjustments and not open to the consumer for adjustments. You need to know what all the settings mean before adjusting(you should not have to). I think the set needs to be reset or the EEProm may have failed because of power surge, in which case you will have to refer to service technician. Every TV uses different software to function. Good Luck, JUS004
Feb 23, 2008 | Televison & Video
Buying a new replacement screen
The blue on my TV off center I was wondering if you could e-mail me a copy of your tv service menu setting I think their wrong.
To access: service menu
off your TV, then on the remote enter - [DISP], [5], [VOL+], [PWR ON]
This will give you the service menu
To scroll up use [1]
To scroll down use [4]
To exit press Power
I need the following settings:
SERVICE VPNT 00 VPOS [???]
SERVICE VPNT 01 VSIZ [???]
SERVICE VPNT 02 VCOM [???]
SERVICE VPNT 03 VLIN [???]
SERVICE VPNT 04 VSCO [???]
SERVICE VPNT 05 HPOS [???]
SERVICE VPNT 06 HSIZ [???]
SERVICE VPNT 07 PAMP [???]
SERVICE VPNT 08 UPIN [???]
SERVICE VPNT 09 LPIN [???]
SERVICE VPNT 10 PPHA [???]
SERVICE VPNT 11 AFC [???]
SERVICE VPNT 12 VBOW [???]
SERVICE VPNT 13 VANG [???]
SERVICE VPNT 15 RDRV [???]
SERVICE VPNT 16 BDRV [???]
SERVICE VPNT 17 RCUT [???]
SERVICE VPNT 18 BCUT [???]
BLU -[???] -[???]
SIZE
BLU -[???] -[???]
SKEW
BLU -[???] -[???]
CENT
Hopefully that will fix the problem.Much appreciated
Sep 04, 2007 | Sony KP-61S70 61" Rear Projection...
HP LaserJet 5si Printer Logo
19 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
