Question about Sony Ericsson P990i Cellular Phone
Connected to wifi but ...get could not locate remote server error in opera!
Hi I can connect to a wireless LAN but cannot use the connection as I get a remote serer error when using the p990i browser! Any ideas, have I missed a setting here?
You need to configure the entire connection manually. i.e. you need to put all the IP address, DNS address , Gateway etc and then only it will connect to the internet.
Posted on Jun 26, 2008
Where to put wireless pasword
Posted on May 20, 2011
I need a pass through wifi router
The best soultion is to install a hub or a network switch.
If your wireless router has LAN ports then connect your computer with a LAN cable to the wireless router.
Feb 07, 2013 | Computers & Internet
I have a WIFI and I heard that I can connect my HP OFFICEJET 5610 ALL IN ONE into wireless using my WIFI connection. Please assist me. Thanks a lot, Toha ****
hi tohafaniwang
the HP OFFICEJET 5610 doesn't have an internal wireless adaptor therefore you would not be able to connect it wirelessly to your wifi network. Although there is an option to get a wireless LAN routher/printserver wherein you would connect the printer to the wifi print server/router using the usb 2.0 cable. using this you would be able to setup that all that connects to your wifi network would be able to print to your printer.
Hope this helps
janc30
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
I'm trying to re-confirgure my nephews laptop. He messed up the internet setting for wireless networking. I was thinking of just going ahead Aand erasing everything and re-install WINDOWS xp , But he has...
ok so you are connected to the wifi network. if your wifi is broadcasting internet and you got server nt found errors, it could be a browser problem...also, are there any other computers connected in the same network that can't connect to the internet? if so, then it is a network configuration error
if it is a browser's error, misconfiguration, etc, try to check:
1. right click on the IE's icon on desktop and click properties
2. Go to Connections tab
3. Click on LAN Setting
4. Check "Automatically detect settings
Make sure also that in your browser, you did not check the "Work Offline" option. Look at it at the File menu
Aug 28, 2009 | HP Pavilion dv6000z Notebook
Cant access the INTERNET thru wi-fi!!!
check the status of connection and check the driver curruption ........
if necessory update drivers ....
Jul 01, 2009 | HTC Touch Pro Smartphone
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Can't Connect to the Internet
Two things you can try before trying your browser/Internet connection:
1. Right click on the Wireless Network Connection Icon, click on Repair. Allow the computer time to repair its WiFi connection and some other settings;
2. Right click on the Wireless Network Connection Icon, click on Status. Click on properties button, select TCP/IP (Internet Protocol), click on Properties button, verify that the option "Obtain IP address automatically is ticked, OK, OK.
3. In your browsers, verify/modify settings:
In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings" (& pls make sure there is no check mark on the Proxy server), OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Pls post back how things turned out or should you need additional information. Hope that this be of some help/idea.
Good luck and kind regards.
Nov 17, 2007 | D-Link Air DWL-122 802.11b Wireless...
Wireless internet connection
Hi, A couple of things you should check: 1. Has the "wireless internet user" enabled his Internet Sharing? If yes, how has is this user sharing it with you, through an AP/Router? 2. If he is using an AP/Router, are there any security settings enabled such as WEP, WPA, or MAC Filter? If yes, you have to get the security key and enter it into your configuration. 3. Is the DHCP Server in the AP/Router enabled? 4. If yes to #3, have you made your networking "Obtain an IP Address Automatically? 5. If no, you have to get/set the allowed IP address that you can use, Subnet Mask, Default Gateway and DNS Servers; 6. Can you ping the AP/Router or at least the "wireless internet" user IP Address. To ping, Start, Run, type "cmd", type "ping IP add of wireless internet user and/or AP/Router; 7. In your browser, enable Auto detect proxy settings for this connection; Pls post back with: a. How do you connect, a wifi card/USB or built-in? b. What AP/Router are you connecting to? c. What browser are you using, IE, Mozilla, Opera? Hope this be of some help/idea. Good luck and kind regards.
Sep 19, 2007 | Compaq Armada M700 Notebook
Sony Ericsson P990i Cellular Phone Logo
893 people viewed this question
Top Sony Ericsson Cell Phones Experts
Sandeep Shenoy
honeybun1986
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
