Question about IOGear Bluetooth Combo Printer Adapter [ GBP301 Wireless ] (113778) Print Server
Problem in taking a print from Nokia 3500 using kyocera printer attached with Bluetooth adaptor
  • 57 Answers
Check your Bluetooth adapter and see if it requires driver. If it requires driver then you can't just plug it in to your printer unless your printer has a built-in drivers for Bluetooth adapters.
Check if the printer supports Bluetooth adapters and make sure that your Bluetooth adapter is compatible with the printer.
Posted on Jun 30, 2009
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
Kyocera mita says install finisher? what can i do. it wont print since it started saying that.
if machine give you this msg it means you need to attache the finisher if finsher attached already just check the finisher swich maybe not attached good
Aug 25, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
We produce a small magazine of 20 pages (A5) using open office writer. The problem is that when we print 200 copies on the Kyocera 3035 it seems to send each copy to the printer in sequence taking well...
for printing 4000 pages in a hour or hour-and-a-half, that is not bad. it could be better.
the changes in the open office not in the printer. Try to send the print job to the printer with spool on and uncheck the print the last page first.
Feb 26, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
RE: Canon Bu-20 bluetooth printer adaptor. I just purchased one and there are NO instructions in the package. Do you know of an instruction page/manual?
With my MX850 printer the bluetooth setup instructions were only in the on-screen printer manual, not with the bluetooth adapter, and not with the printer documentation.
In my case it didn't help as Windows is not discovering the bluetooth adapter for some reason.
Jan 08, 2009 | Canon BU-20 (13803055436) Print Server
Some reports will not print
you will need to disable  the netware setting and maybe the appletalk setting via the browser.
make sure you have the i.p address of your printer and enter it in the address bar
Jul 15, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
MacBook cant locate Kodak EasyShare 5100 printer using IOGEAR bluetooth adaptor
having same problem with same devices, macbook pro, kodak 5100, and that iogear bluetooth adapter...im getting desperate...
Jan 13, 2008 | Office Equipment & Supplies
Computers & Internet Logo
Top IOGear Computers & Internet Experts
castletech
castletech
Jose Velazquez
Jose Velazquez
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
