Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Help i have a hotpoint auqarious wd420 whilst cleaning the front of the machine i washed all the cycles from the front panel what are they? e.g.: i now can't do a wash as i don't know if i am putting it on a fast wash or a boil!!
  • 57 Answers
THERE ARE ONLY THREE THINGS I CAN THINK OFF FIRST I WOULD SEE IF ANYBODY I KNOW HAS A MACHINE LIKE MINE AND MAKE A DRAWING OF THE CYCLES YOU CAN JUDGE BY THIS OR YOU CAN CUT YOUR DIAGRAM AND STELLOTAPE IT AROUND THE DIAL THE WAY IT WAS STAMPED ON FIRST. SECOND YOU CAN GET ANOTHER SECOND HAND FRONT PANEL AND GET IT PUT ON. THIRD YOU CAN GIVE UP IF THIS FAILS AND BUY ANOTHER MACHINE
Posted on Jul 15, 2008
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Broken machine door handle :(
Unplug at the mains, remove lid and door catch can be released from inside the machine.
Sep 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
Feb 08, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hello, I have a hotpoint aquarius WD420. The machine first started playing up by not pumping out properly, and aborting mid cycle qith an error code, after the first pump out. I removed the filter / float...
Did the circuit board get wet?
Its behind the fascia panel.
You will need to remove the top cover to see.
Screws are at the back of the top cover.
Remove them and slide the top backwards to get the top off.
Look for any water marks.
Best luck
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
