Xerox workcentre printer drivers
What are/where can I find the control codes (to add to a program written in a high level language) to change from B&W to color, and back, under program control. I don't want the user to have to worry about doing this.
Thanks
    President:
  • 2,072 Answers
You know if you rated fairly maybe someone would consider helping you.
Posted on Jul 06, 2008
After I install my xerox 3119 scan driver I can see the program installed..not in my computer or in add or remove programs but i can see it in C/ Programs/ xerox
if not that in scaner unit in control panel.?
if you know file name type that in "search unit" and find that?
if not , remove that and install in other directory ?
if not , change driver! .
Apr 16, 2011 | Xerox WorkCentre 3119 Laser Printer
How to install xerox workcentre M118 for windows 7 64bits
I am one of the technician trained and specialized in different computer  and printer manufacturer.
Here is one of the instruction on how to install your printer to windows 7 64 bit
-run the driver downloaded from the site, then select the location
http://www.support.xerox.com/support/workcentre-m118-m118i/downloads/enus.html?operatingSystem=win7x64&fileLanguage=en
-Go to Control panel
-choose devices and printers
-add a printer
-add a local printer
for Standard TCP/IP port has already been created on the computer, choose the port from the Use an Existing Port pull-down menu, next, and then skip to step 10.
For the port has not been created on the computer, choose the create new port button, choose standard TCP/IP from the Type of Port pull-down menu, click Next, and then continue with step 8.
-put the IP Address or hostname of the printer
-check if the query for printer is set to automatic, then next
-choose have disk
-choose browse, then select where you save the driver
-choose the required printer model
confirm the name of the printer
-choose do not share, then next
-choose finish
for more information visit:
http://www.support.xerox.com/support/workcentre-m118-m118i/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Contact number:
English 1-800-821-2797
Spanish 1-800-821-7726
Hours of Support - 24 x 7
I hope this will help a lot.
thank you for choosing Fixya
Feb 27, 2011 | Xerox WorkCentre M118 PCL 6
Printer WorkCentre PE114e. Drivers for Linux.
The PE16 is listed as a GDI printer. This means that the laser imager within the printer is directly controlled from software, not from firmware through a portable printer language (such as PCL or PostScript).
Such printers are easier for the manufacturer to engineer (they're all software), but the "driver" must be specifically tailored for each OS. There's no Mac OS X driver for the PE16/PE114e either, they're listed as "Compatibility Level 5" (a fancy way of saying "NONE"):
http://download.support.xerox.com/pub/drivers/Compatibility_Matrix/other/macosx/en/MacOSX10-6_Matrix.pdf
Jun 07, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
How to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
May 20, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Changing print properties shuts down all open programs instantly!
I would first of all Go to the Xerox.com site and go to Drivers and downloads for the M20i and install the newest firmware. I believe the current version is 3.4.
I believe your problem would be resolved in loading the newest machine firmware.
May 05, 2009 | Xerox M20I Printer
Need Drivers for Xerox XD105F for Vista - Do any exist and where
try this link > http://drivers.softpedia.com/progDownload/XEROX-Printer-WorkCentre-XD105f-501230001-Download-2253.html
on the right side there is a DOWNLOAD LOCATIONS
for XEROX Printer WorkCentre XD105f 5.01.2300.01: and below is EXTERNAL MIRROR, click this mirror and save the file. Scan the program prior to your installation, file size is about 4MB. Let me know if there is any other i can help. regards. cebuwano
Apr 11, 2009 | Xerox WorkCentre XD105F Laser Printer
How to programming the Language?
You have to contact Xerox technical support to change the language on this machine.
Here is a link to download the guides for this machine:
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=DC12LP&Xlang=en_us&Xcntry=USA&prodName=DocuColor%2012%20Printer
  • Customer Technical Support Center:
  • 1-800-821-2797
  • Hours of Support - 24 x 7
  • Have the Serial Number written down before calling.
  • Jan 16, 2009 | Xerox DocuColor 12 Printer
    What is a compiler and ite story
    A compiler takes code that you have writin, and 'compiles' it into machine language code ex.10010011, a language that your computer can understand and execute.
    Jan 15, 2009 | Computers & Internet
    Xerox Workcentre Pro 123 error code 016-719
    this is not a mechanical error but a software error.
    It either doesn't recognise the format or program
    as for the driver don't thinkit's the problem the HP can use PCL6
    Sep 08, 2008 | Office Equipment & Supplies
    jasbo
    jasbo
